pump
Results 1 to 9 of 9
pump
    Smokin Whitie hondo jim's Avatar
    Northener
    Default pump
    picked up a pump dont know anything about it.looking for some help.where do i look and what for berkley soposed to have a new impeller in it .said you need atleast 600 horse to run it.anyone have any info and what its worth.
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Quote Originally Posted by hondo jim View Post
    Hey Jim what pump is it? 12jg, 12jc??? flip it over and look up in the suction housing and you can see the impeller, if it's new the leading edge's of the impeller will be sharp and clean, if they are rolled over ,or have dinks in it most likely its not new, also check the front thurst bearing to make sure it spins freely!!!!!! if you don;t sell it before the races bring it down and i'll check it out for ya! or take some pics of it!
    See ya at the races bro!
    Tye
    Northener
    it has a stanless steel impellar
    600 horse at what RPM? It's not ONLY how much hp you're making, it also matters at what RPM you make it at.
    Northener
    not sure dont know anything about it.how do i find out and does anyone need it
    The main thing we'd like to find out is what size impeller is currently in it. If you can take the bowl off of it, the size should be stamped on the back of the impeller and it will be a letter, such as C, B, A, AA, etc etc.
    Las Vegas, Nv
    The pump should have a silver tag rivited on the top of the suction housing, just on top of the thrust bearing. This tag has info on it that identifies the type of pump and somtimes the impeller size.
    If You could post a pick it would be easy to tell for You....H
    Newton Ks.
    As long as it wasn't cut w/o being re-marked.
    H.L. Mencken
    Northener
    thanks fellas ill check it out tomorrow.
