Steering Help
Results 1 to 9 of 9
Steering Help
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Default Steering Help
    Does this steering sprocket look worn out if so where can I score one quick
    Shhh!! Can you hear that?? GJ
    Quote Originally Posted by GottaJet View Post
    Can tell from the picture, can you identify the brand typically printed on the actual cable jacket (Morse ,Teleflex etc)
    Santa Clarita,CA
    It's a morseClick image for larger version.
ID:	371137Click image for larger version.
    It turns but it seems like the pictured gear is stripped unfortunately not one part number anywhere!
    Santa Clarita,CA
    Senior Member SBS933's Avatar
    Jun 2012
    I replaced my whole steering deal, It was cheaper than parts.
    Believe Nothing you hear and 1/2 of what you see.
    California
    That's a Command 290, its was superseded by the Teleflex Safe-t. Don't believe the Teleflex helm is backwards compatible with the Morse cable though. Either the Telflex or the Uflex systems are direct replacements for the entire setup.
    Santa Clarita,CA
    It's on a 94 Lavey..do you know the part# for the teleflex I should look for and is it necessary to replace the cable as well?
    Why are those such pieces of sloppy crap that you have to buy a whole new box? Mine has a ton of play also. Was going to take it apart, but it doesn't look like there is anything to fix.
    Santa Clarita,CA
    That's the same conclusion I'm coming to. Thanks guys I really appreciate it. JBP my buddy is going to give you guys a call tomorrow. Thanks again
