jet pump intake psi gauge
Results 1 to 3 of 3
    Jan 2011
    Default jet pump intake psi gauge
    I am blowing out my intake gaskit and my clean out cover after a hard 100 mph pass. where should the pump housing be drilled for a psi gauge and what psi should i be looking for?
    Jan 2013
    Magic Mountain CA
    I spoke with Duane at HTP about this many months ago, I think I remember the correct area. 1-2" in front of the wear ring on the side of the pump. I have a gauge, but haven't gone their yet. I don't know what the pressures should be.
    http://www.performanceboats.com/jet-...-location.html
    sounds like you have a surface matching issue. you need to make sure those surfaces are flat
