Eliminator Sprint
Results 1 to 5 of 5
Eliminator Sprint
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Default Eliminator Sprint
    I am now involved in the restoration of an '84 Eliminator Sprint. I am supplying the engine and doing some of the rigging. Seems to be very light, maybe 550 lbs. I am told that they only built this version of the Sprint for 6 months in '84 but pulled it from production because it was fast but a little unstable at high speed. Does that sound right, or am I buying into an urban legend? Pics to follow. Thanks.
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Team CJ460 Just Electric's Avatar
    granada hills
    never heard of them unstable but been told due to the bottom they run hard to the 8th but tend to nose over a smidge.i still have the delta bottom on mine and have done a few things and got it to air out pretty good with some help and advice from many of the pros and few peeps here on the boards that ran delta bottom jets at the races
    San Dimas CA
    Quote Originally Posted by Just Electric View Post
    Delta Bottom, you say. Is one of the fix moving the pump back several inches? I have seen that before. While the boat is now stripped down, should I find a knowledgable glass man and have the bottom reworked? Thanks.
    Senior Member howler439's Avatar
    On my "Howler" boat the clean out is 1/4" shy of clearing the transom. Its been 101 mph with a 10.34 et. I still have the cleanout inside the deep transom adapter , I have always wanted to do transom plates around the pump. Maybe I'll get that done this next makeover. Forgot to mention both of my Sprints are 1979 models , Howler was built with narrow stringers and setback pump. The work to it was done when it was built. The Jus Fun'n boat was built with thick stringers and standard pump location. Cheers Jim
    granada hills
    Quote Originally Posted by howler439 View Post
    seen cool pics from the drags on your boat it rides nice did you do any bottom mods or left the pad on the race boat.id like to pic your brain too
