[Question] 440 mopar
Results 1 to 7 of 7
440 mopar
    Sep 2013
    Default 440 mopar
    Hello everybody.new to this forum.i used to have a 75 taylor jet boat with a 460 ford .i am looking to buy another jet boat without a motor because i have a 440 motor that i built for a drag car.does anybody still make parts to install this motor in a jet boat.thanks for any help.thanks bill fields
    Quote Originally Posted by William D Fields View Post
    I build everything for it.
    Sep 2013
    Default 440 mopar
    THANKS FOR THE REPLY.WHAT ALL DO YOU MAKE & PRICES.CAN YOU SEND SOME PICS TO MY EMAIL. [email protected] AGAIN.BILL FIELDS
    Welcome William , best of luck on the 440 project was fortunate to be a Mopar tech many years back in the day and have built a few Jet and V-drives with 440's over the years with good success These were great American Iron power houses and all to often passed over for marine applications IMO
    Sep 2013
    Default 440 mopar
    Can you post more pics please of 440 installs.what kind of cooling setup do you need.want to use thru the transom system.what about the driveline system.can you still get the flywheel cover or do you use something else now.i think the rest is pretty straight forward.what about motor mounts.thanks for all y'alls help.bill fields
    Dallas, TX
    For $3500 this would have all the parts you need. You could sell the boat after you get what you want from it to recoup some of your money. I am surprised no one has mentioned that a marine motor is typically clearanced a little differently. Many a great street/strip motor has been destroyed quickly by putting it in a boat without prepping it for marine use.
    BRENDELLA JET BOAT ---- DUAL CARB TUNNEL RAM INTAKE...............
    I can only find pictures of the water exit plates and a poor picture of the PTO takeoff. The parts look similar to the pictures already posted. All of my parts are CNC machined and custom fit to your setup, so anything I would make would be designed the way you want them.
    I have always used a section of the bellhousing and a plate I make that I weld to the bellhousing. The B/RB engine family starter bolts to the transmission, so in a marine application, this needs to be addressed somehow.
