block number?
Results 1 to 7 of 7
block number?
    Senior Member nos1967's Avatar
    Default block number?
    Can anyone on here tell what motor i have from the block number? i cant figure out if its the 330hp or 390hp marine power 454, the block number is 1011482. the boat is in so cal and im in puerto rico so if the block number isnt enough i have to call my dad and have him pull a valve cover.
    if it has the Marine Power serial #
    they should be able to tell you the HP rating.
    I dont think a block and /or head # will give you the HP of an engine
    Lexington, KY
    Exclamation
    Are you asking about the block # or the head #??? Head # is under valve covers, block # is on back of block, above flywheel.
    If you're asking about the block #, I wasn't able to find a 1011482, but I did find a 10114182. And it says 454......91-up.......4-bolt, Gen. V. And the closest thing I was able to find (to what you posted) in the head #'s was 10114156, and it said 91-up.....oval.....open......Gen. V & VI 454, 118cc chamber.
    Hope this helps.
    HJ
    that was the block number, my dad read it to me over the phone so that extra "1" was probably left out. the model is J4545-CAL, serial is 15806, it lists another block number which is TO3245XYB. but marine power doesnt seem to have an active web site right now? hasnt had one for the few weeks ive been searching...
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Everything you ever wanted to know about casting numbers here.....
    http://mortec.com/
    welp i have the oval port heads so that means 340hp 454, now i need to figure out for sure if this motor has the forged parts like the 390hp 454 does. I know it has flat pistons which gives me a lot of options, unless they are cast then i have a whole lot more work to do then i was hoping.
