caulking
Results 1 to 14 of 24
caulking
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Default caulking
    what's the best type of caulking to use around the transom adapter/transom plates?
    Senior Member cbcp's Avatar
    Carlsbad
    Clear Marine grade silicone works good. But everyone has their own preference.
    silicone, i just use whatever color matches the t/a adapter. if its black, i use black silicone, etc etc. tape off the transom before putting the ta adapter on, so when you make the seal, you can pull the tape off and have a nice clean line of silicone, makes it look like you know wtf you're doin
    Tacoma Wa
    Cool idea on the tape. I always just used silicone and took my time. Im gonna use that tape method from now on.
    lol, right..... Devilman's Avatar
    South Texas
    Quote Originally Posted by LuckyDaze View Post
    Same here, tape trick sounds pretty good though.
    And lookin like you know WTF you're doin is always a plus, lol....
    tape trick works nice on the bowl to t.a. adapter as well
    Senior Member sleekvino's Avatar
    the tape thing is the way to go,also make sure its 100% silicone.
    South Texas
    Whats a tits n' ass adapter? lol
    Quote Originally Posted by Devilman View Post
    i could show ya but i'd get banned
    DAP (brand 100%) for da boats
    medical grade for the [email protected]
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Ladera Ranch
    Transom adapter needs no silicone as long as it sits flat on the transom. Coat the gasket with some grease and install. Very easy to remove and does not leak a drop. Try it!
    Member TrynPas's Avatar
    Litchfield Park, AZ
    That's the same thing I do with my valve covers, I use silicone to seal the gasket to the valve cover then use grease to seal the gasket to the head so I can remove/replace them easily/cleanly.
    You done got my kentucky ass all confused!!!
    Culver City, Ca
    I should have been a bit more specific. My pump is set back and rather than a transom adapter the boat has a flat transom plate. Outside the boat around the suction piece and intake there's a bead of some kinda silicone caulking. It's all stuck really good still, with the exception of the area below the intake. Started out as a very minor leak and has progressed to be a big leak. I've got the affected area cut out, just need to caulk it back in. The area is below the water line.
Name:	pump wide angle.jpg
