straight or a droop snoot
Results 1 to 11 of 11
    Senior Member katchenup's Avatar
    vacaville ca.
    Default straight or a droop snoot
    anyone have expereance with a straight snoot verses a droop.
    78 eliminator with a delta pad.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    no but you will when you get done tuning
    Quote Originally Posted by 78CoLeBBF View Post
    yep, try em both.
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    Let me know if you end up trying both, I have a delta pad boat as well with a droop on it. I was thinking about trying the straight.
    Ryan
    vacaville ca.
    I run with a droop on it now, and it runs real good, I'm thinking less bend of the water better performance. It's a billet straight snoot, will try it and see what happens. Was just hoping that someone has already tried the change and could express their thoughts on what they achieved.
    vacaville ca.
    Quote Originally Posted by slowboy View Post
    Ryan
    What type of speeds are you achieving with your delta pad.
    Golden Shores,AZ
    i know i picked up with a straight snoot but my boat is a v-bottom and is not a delta pad
    Senior Member JDG911's Avatar
    MESA
    i have a v bottom and a tunnel tried both way on both boats it just comes down to what the boat likes straight on my pickle and droop on my v
    Golden Shores,AZ
    we used a rooster booster on are texas tunnel you say it like the straight snoot nice maby a little better et sittin in the hard ware
    vacaville ca.
    I have a v-bottom as well, the delta pad is flat right in front of the intake, It's 8 1/2" wide and roughly 36" long.
    Duluth, MN
    Quote Originally Posted by katchenup View Post
    The boat will run 83 on gps with 2 people in it. Engine and boat are not set up correctley......yet. SBC 91 octane.
    Looks like the weather is going to be nice today, I have a new loader I would like to try out.
