I'm thinking
Results 1 to 14 of 31
I'm thinking
    Banne'd Cobra1's Avatar
    Default I'm thinking
    this
    With this
    In my 20' tunnel/deck boat would make a good little drive package.
    Yes or no???
    The Right Coast/SE-PA
    Thumbs up
    I've been thinking the very same thing (engine wise) for a few years now. And research tells me the big HP 12.0:1 572 can run off pump(93 octane) gas if the total timing is backed down to some 28 degrees.
    I still have the issue of Hot Rod Magazine (June 04)with the write up they did...they also ran it on pump gas >91 octane.
    Duane from HiTech Performance has installed a few with very good results. For my peace of mind I would tear it down and check all clearances.
    Note...after a mild tune-up peak corrected HP was 801 @ 6,300 rpm and 738 lb-ft at 4,500 rpm this of course with more total advance and race fuel.
    Lets buy two and get a discount!
    Senior Member desrtrat256's Avatar
    San Diego, CA
    Ive always wanted to to an LS series motor. why hasnt it been done yet. Fuel injection, light weight, small block that will still make 600 reliable horse power and equal in torque. decent gas mileage and alot of adjustability with a laptop. And the best of all is it can still be done relatively cheap
    Well all I have to do is get my HIN from the Coats Gaurd, a Bus. licence, and buy them at OEM prices. Oh yes that will save a bunch.
    What's the cam profile like? I haven't looked at that yet, might have to change that??
    Quote Originally Posted by Cobra1 View Post
    ... What's the cam profile like?
    Well hurry up and get that licence...I'm waiting!
    Cam info on the 12.0:1 720 HP 572
    Mechanical Roller 0.714//0.714 lift
    266/274 duration @ 0.050
    If I recall correctly what I was told a shop does is to change out the oil pan, swap the Demon carb for a marine (liability reasons )back down total timing and instruct the boat owner to break in the engine easily.
    Lexington, KY
    Wink
    Quote Originally Posted by desrtrat256 View Post
    Here ya go, Eagle has done em all. LS2
    And my personal favorite. LS7
    Actually this one is my favorite.
    HJ
    Lexington, KY
    Question
    What is everybody's opinion on the Legend drives? You don't see too many of them around, and I remember a thread about the best jet pumps, and Legend didn't end up in anyone's top 5.
    HJ
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    Have you priced that beast?
    You can build one for cheaper using better aftermarket parts. That ZZ572/720R requires 110 fuel (12:1 compression) and the cam in it would probably need to be changed to be more 'jet boat friendly'.
    By the way, the list on that is $19,568.
    Race
    Senior Member CK7684's Avatar
    Minnesota
    If I had to do mine over again, I would just buy a 572. I have just as much $$$ into my 468...
    Quote Originally Posted by RaceFace View Post
    Wow the price has really gone up! Few years back it was +- $14K.
    And again...Hot Rod mag did the test and it did run fine on 91 octane "pump gas" by just backing the total timing.
    Mission Viejo
    Which issue? Im looking at the Oct 2008 issue right now. They tested 8 GM crate motors in a '69 Chevelle, one of them that motor and all they did to that motor for the test was back the jets off because it was running fat. No timing change.......or did I miss that page?
    Race
    As I mentioned in post #5...HOT ROD June 2004 page 20. They do a nice write up on 572/720 HP 12.50:1 AND run it on 91 pump gas!
    Fully tuned on race fuel it made 801 HP.
    I'll scan in a few pages later and post it up.
    Mission Viejo
    No biggie, I was questioning whether I was blind or not in this new issue. I have long since thrown away my '04 Hot Rod and I have drank alot of beer since then, so those memory cells are long gone! LOL!!!!
    Race
    Here's a few pages...
