Bottom Hook
Results 1 to 14 of 84
Bottom Hook
    Large Member edog's Avatar
    Riverside, Ca
    Default Bottom Hook
    I hear people talking about taking hook out of the bottom of the boat, to get more MPH.
    Why is there hook in bottom to begin with?
    Lexington, KY
    Lightbulb
    Quote Originally Posted by edog View Post
    Because the curved shape creates a low pressure zone when water passes by it (kinda like an airplane wing), thus creating suction. Which pulls the hull down into the water a bit, making it more stable, but in turn the hull will be slower. With a perfectly flat hull very little suction is created so the boat flies higher, thus the hull will run faster. But it is also less stable, thus the boat is more dangerous.
    HJ
    some may have a lil rocker in them on purpose, research the hull brand well and make sure this is not the case if you take out rocker that was meant to be there, it may buck and porpuse like crazy on ya from then on
    Banne'd Cobra1's Avatar
    Hook and rocker go hand in hand. If you look at some of the new ski boats they claim to be "trimable". Not really. They have rocker built in and they use a trim tab of sorts to force the nose of the boat down. Then when the lift the tab the boat starts to rock back on the tail end. Hook is there for a reason. If you remove it your going to have a heluva ride. And at slow speeds a sucky ride.
    Tacoma Wa
    Not always. There was a feller here who blue printed the bottom of his hull took out all of the hook, and then couldn't get it to stay in the water. You know when you dole out information you'd better make sure its correct or you know what your talking about....
    Hook can also be caused by an improper fitting trailer warping the bottom of the boat.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    jack at MPD told me i need to leave 1/16" to 1/8" hook in my hull or it will want to porpuse.
    Lexington, KY
    Exclamation
    Quote Originally Posted by LuckyDaze View Post
    Re-read what I wrote. That is exactly what I said. Remove the hook, and the boat is going to fly higher, and on some boats it may even want to fly completely out of the water.
    And I know all about the improper fitting trailer thing.
    HJ
    Edog ,start on a good surface (garage floor) with a mat or creeper and a good 3' to 5' foot straight edge and check the boat bottom carefully for "distortion or uneveness" especially in ares where it sets on the bunks etc call if you need more info Tom
    460
    460 is offline
    ATTA BOY 460's Avatar
    Im going to say and sum can back me up but not every boat needs the hook taken out to ride on top of the water. I talked to the builder of my boat and he told me to leave it there or im asking for trouble. Matter of fact he used the word PORPUSE. You need to do your research before you start taking hook out. Could end up hurting you in the end
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    Ya gotta love this guy. His boat has been in the water for 2 weeks and has jet boats ALL figured out and is throwing advice out.....especially with the way his boats PLOWS through the water!!! YOU DA MAN!!!! NOT!!!
    Just a tip....a high post count doesn't mean you know shit about jet boats...and we ALL know you do not have the seat time to give advice....especially when you don't take the advice yourself.
    As I have said before, there are alot of VETERAN jet boaters who don't come in the jet section anymore because they are tired of ALL your threads, your lip service in their threads, and your inexperienced 'advice' to other jet boaters. Take a rest for a while and let the veterans come back and enjoy the boards they helped start. They are the ones that should be giving advice, not you...and when they try to give advice to someone else, shut up...whether you are 'misquoted' or not or whether you think you know or not.
    I guarantee you, there are alot of jet boaters on these that have spent more time in the seat than you have on this earth...myself included. Your sled floats and runs, go use it and get some seat time and give the rest of us a break.
    OR you can hit another angle and see if the mods will start a "HJ's Hawaiian" section in Tech.
    Race
    Menifee
    Quote Originally Posted by RaceFace View Post
    My name is Quickjet and I approve this message!.......
    Keith...
    Kingman/Golden Vly, Az
    whoowee...tough crowd!!! ...but, i do agree & approve this msg also
    FastRat
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Step away from the keyboard
    I second this request
