NOS boss
Results 1 to 12 of 12
NOS boss
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default NOS boss
    I have my manifold off and was thinking of drilling and taping the bosses for NOS. Is there any trick to this were a machine shop would have to do it or can I just drill and tap my own holes? Also, is there a place in or near phoenix that can polish or add a coating of some sort? (Dart tunnel ram)
    i've done a few port injected nitrous deals and they were pretty easy to drill and tap, the trick is keeping the same angle on each runner matching the rest and nozzle placement. biggest trouble i've ran into doin those kits is bending the tubing, that shiat suxxxxx
    Kingman/Golden Vly, Az
    Quote Originally Posted by Master Sergeant View Post
    ck with the boys from down there...they can turn u on to where to get it polished...also...i think Jet-Hot (they coat headers etc) is down there somewhere!
    FastRat
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    Ask squirtn my load. He had his entire jet powder coated. The same shop might do what your looking for.
    Quote Originally Posted by NO BUTT NO PUTT View Post
    i used southwest powdercoating on 59th ave & van buren, lots of problems and it took a month +. if i had to do it again i would ship it off to embee.
    Senior Member tx-19's Avatar
    wittmann,az
    affordable powder coating,and fernandos for polishing.
    B1 Racing cs19's Avatar
    What manifold is it? Done a Dart TR before and its a pain cause you have to mill a pocket to thin out the runner before you can drill/tap. If you dont thin it out the nozzle wont be deep enough in the runner.
    CS
    B1Racing.net
    Senior Member Green w Envy's Avatar
    Edmonds, Wa
    I did my victor, but like the others said, make sure you keep them all the same angle, I created a jig and set that up to make sure they were all in the same place.
    Darin
    nice job darin! bet that sob hits hardddd
    So Cal
    Hire CS19 @ B1 Drag Boat Development ... his work is second to none
    Santa Clarita
    Quote Originally Posted by BUSBY View Post
    The boy has some talent for sure.
    Edmonds, Wa
    It does, especially after you hit the second stage!!!
    Darin
