Puke tanks
Results 1 to 14 of 62
Puke tanks
    Senior Member bc18's Avatar
    Default Puke tanks
    I know what they are used for but what makes the oil spit out of your breathers?
    Morgan Hill
    Quote Originally Posted by bc18 View Post
    If you have ever pulled the breather off of a high performance engine while its running with a new white shirt on, you would know the answer to that question and have the shirt to prove it.....The amount of "blow by" created in an engine at high speed is and can be a lot, the oil mist thats created collects in the valve cover and gets blown out, a vacuum pump is one alternative, this makes the cranckase pressure negative and allows the rings to seal better...
    Puke tanks work very well at controlling this phenominom.
    GT
    GT
    So pretty much its just pressure build up that has to go somewhere which in this case releases out the breather and spits oil out? Anything or reason this may happen?
    hole in the piston will do it
    #55
    Senior Member cave's Avatar
    Mesa, AZ
    like this one
    Takin it home
    Lexington, KY
    They do it even if there isn't a hole in the piston, right?
    I sure hope so, cause if not then I've got a hole.
    HJ
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Better yet, fire up the motor, when the Valve cover is off! alot of shit goins ons, i learned that back in the third grade when my dad yelled at me...."Get your uncle a towell!"
    Even @ the third grade level, it was single handedly one of the funniest things i have whitnessed in my life, but it was my dads boat! I was the cleaner upper from that point foreward! lol
    I miss my youth! Fukkin rednecks!
    TRG
    TRG is offline
    Not Poking fun here bro!...but the uncle im talking about here lives in Union County KY!
    He cannot change the oil in his own Conbine!
    Morgan Hill
    Almost all engines have some amount of blow by, that is why most automotive engines use a PCV and a closed air cleaner.
    The reason for this is the ring sealing of the piston is not 100%, what gets by creates "cranckase pressure".
    Totally normal IMO, most of the engines we use in our boats were never actually designed to run at 5,500 RPM for any length of time, or sometimes even at all....
    GT
    Default Puke tanks
    Thats what I call the commode after a nite at my Bros and some Cabo Wabo
    Morgan Hill
    Which, the hole in the piston, or the puke tank?
    GT
    Whats up Glenn !
    Morgan Hill
    Just hangin' wishin I had some of that Cabo Wabo!
    You need to paint that motor black, way too chiney
    Oh yeah bc18, a little blower, turbo, or nitrous will cause a little oil vomite too...
    GT
    Come down to SA next weekend , Classic Vdrives 3 day campout 1 good times be my guest ! Tom
    sorry for the thread jack
