Rack Steering Setup
Results 1 to 14 of 31
Rack Steering Setup
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    Default Rack Steering Setup
    Does anybody have a diagram for the parts needed
    for a rack style steering? Mine has a shaft that goes
    inside the bezel & a through bolt all the way to the
    rear of the gears. I'm sure i'm missing a part because
    when tightened it wont turn (bottomed out), and it's
    pretty sloppy? It's been a long time since I took it
    apart & I can't remember all involved??? I'll post some
    pics soon. Thanks guys!!
    You may find ,you have to buy a whole new kit, rack and pinion/cable combo. What are you workin on?
    Antioch,Ca
    74 Kona, I know it all works, I just think I misplaced
    a piece? I'll get a pic on here when I get home....
    Quote Originally Posted by konajet74 View Post
    Kona ,if I'm reading right (re the "thru bolt") ,the rack set up you currently have is a "Ride Guide" and truthfully its simpler and easier to simply replace the whole "shootin match" with our "rack in a box system" retro fits right in ("Cake") call if we can help you Check pms for my cell if you need help Tom
    PS if you are simply missing a couple of small pieces with have loads of "spares" (we save everything)
    Antioch,Ca
    Thank you Tom! I'll post a pic when I get home so
    all is clear. I think I'm missing a washer or?
    Happy to help Tom
    Antioch,Ca
    Well, I think I got it..... There's a hard black plastic
    piece that goes around the splined shaft I had installed
    at the rear (towards the front of the boat) which should
    of been forward. I also found a beat up large nyliner that
    goes right under the steering wheel adapter just inside the
    bezel. Anyone know where to get a large nyliner (1 1/4"-
    1 1/2")???
Name:	Jet Boat 043.jpg
ID:	21198   Click image for larger version.
Name:	Jet Boat 044.jpg
    Clovis, Cali
    konajet74, There should be 2 of those black plastic pieces (one at each end) and a washer (it fits into a groove on the back of the dash piece).
    Here's a pic of the splined shaft out of the rack with the pieces in place. Hope this helps, let me know if you need any more pics while its apart.
    Member blownt's Avatar
    Houston, Texas
    I just bought a whole new SS141 Rack System for $120 to replace the old one that was real tight. Most places want that much just for the cable.
    https://www.surplusunlimited.com/Mer...y_Code=2200-60
    Kona got those little misc pieces and large nyliners in some bins if you decide to go that way . Call me Tom
    Antioch,Ca
    Propless, that's exactly what I needed, Thank You!! I'm
    missing one of the black pieces, a washer & I need the
    Nyliner.
    Tom, I'll call you in a while!
    Thank You guys for the help! This website is awesome &
    has helped me immensely.
    Default parts
    heres the pieces ? Tom
    Antioch,Ca
    That's them! Thanks for looking Tom, I appreciate it!
    You definately got my business!
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    And when putting that beauty back together, make sure to put the rack on the BOTTOM of the pinion. I was rebuilding one of my jet boats and decided that it would look nicer up and out of the way. We got it to the ramp a week later for its maiden voyage and as we're backing it off the trailer, I realize that the steering was ASS backwards!!! I attempted to trailer it by driving it on.....no way!! I even looked at that SOB in the garage....TWICE and STILL had it wrong! LOL!!! I did a quickie parking lot job and swapped it back.
    Race
