advantage Banchee anyone seen one run fast?
Results 1 to 8 of 8
    Senior Member Tony Skagen's Avatar
    Default advantage Banchee anyone seen one run fast?
    I have ran eliminator scorpions and I know that the parellel bottom does not work well.Advantage banchee which is a copy but has stepped outer sponsons so I would think it would work well at speed,the outer sponons would free up.But I never see them run.
    Bullhead City, AZ
    Yep, 98+mph, but that was with a 2.4L Bridgeport Merc.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Thanks but im talking as a jet.
    we all know jets dont run fast just ask those wacker guys
    #55
    Long Beach
    We built many more jet Banshee's than outboards, but the outboards ran much better than the jet. Very wet ride unless you're running lots of hp. We ran one with a near stock, single carbed sbc with a OMC King Cobra I/O at either 116 or 118 mph to get the ETII record in the kilo back in the mid to late 80's, record still stands as far as I know. Good hull, just takes gobs of power to make it run right with a pump.
    000-OnRe! If Looks Could Kill's Avatar
    Sep 2008
    Upland
    Quote Originally Posted by old rigger View Post
    What years did you work for advantage? You might have rigged my
    first boat, 1986advantage 18' bubbledeck
    Thanks for the info Old rigger! I am thinking of taking a scorpion and changing the outer sponsons similar to the banchees then doing some small mods to the center pod.I currently have 19 daytona but I always liked the look of the banchee/scorpion.I have some good power about 1200 hp blown 598,but the end result I hope runs as fast or faster then the daytona. What is you thoughts?
