New build ideas
Results 1 to 14 of 39
New build ideas
    Swollen Member SinisterGrin's Avatar
    Talking New build ideas
    Ok, so I picked up a hull awhile back and haven't done anything with it until now. This winter I'm starting the build on this thing. Its a 81 18ft Haskell Jet with a berk in it and a full stringer. Now from what I understand these pretty much all came with panthers but I found one that came with a berk thus the only reason I took it (and the fact it was 800 bucks). I checked and it hasn't been converted or anything and everything checked out. I hear these are also a pretty fast hull, can anyone verify this? Reading is one thing, first hand experience is alot better. My question is, I want to do something new, not the same straight up jet boat, then again I don't want some outlandish crap, I already have enough of that. Heres the boat-
    This is the "newly rebuilt" pump that was in it and when i pulled it apart it looked exactly as I thought- about half and impeller and a 1/4 inch groove in the suction( thats history) and had the remanants of a jet-o-vator
    So I got a new suction from CP used and took the bowl, suction, and transom plate and bead blasted off all the crap powdercoat and used a ton of coats of the merc black outdrive paint and then cleared it a couple time, little dusty but here is pic-
    Already have the pump rebuild kit, black diverter, and a 655 HP BBC Ready but don't want to just throw the stuff in there, any suggestions?
    Here is a pic of the boat in the water from the last owner-
    Thanks in advance
    Morgan Hill
    Two letters "CJ"
    Let's go play!!!!!!!
    GT
    Just Me snoc653's Avatar
    Eastern Iowa
    Quote Originally Posted by SinisterGrin View Post
    Ok, so I picked up a hull awhile back and haven't done anything with it until now. This winter I'm starting the build on this thing. Its a 81 18ft Haskell Jet with a berk in it and a full stringer................ My question is, I want to do something new, not the same straight up jet boat, then again I don't want some outlandish crap, I already have enough of that.
    Thanks in advance
    Does this mean running a duramax with tractor pull headers (straight up) through a z drive with 58 percent gears overdriving the pump is out of the question? You could call it Long Black Train.
    Then I'm gonna need a killer set of mud flaps lol
    Morgan Hill
    Don't forget the gunrack!
    Eastern Iowa
    Don't forget better seats, you'll need something that will keep you in the boat. A duramax spinning twin turbos will crank an easy 1000HP and even bigger torque numbers. Instead of mud flaps (unless you wanted them on the trailer), put the flappers on the pipes and a locomotive airhorn on the bow. If you turn the horn around facing backwards like it should be mounted, don't forget hearing protection. And most boats already have a gun rack, although some of those city folk stick a paddle where the shotgun is supposed to clip (Go figure).
    Lexington, KY
    Talking
    I got an idea.......send it to me.
    I'll give ya' $801 for it, everybody wins, lol.
    HJ
    add another 0 and its yours lol
    Morgan Hill
    Well hell, why didn't you say so, I'll make it two more zero's $801.00
    Eastern Iowa
    I think he wanted that zero added to the other side of the decimal point. So I'm going to offer him $0801.00
    Morgan Hill
    Sorry, My Bad
    Lexington, KY
    LMAO!!!
    Ok, back to the topic at hand. How much money ya got? I'm thinkin' EFI twin turbo BBC.
    HJ
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Cummins 5.9L twin turbo!!!!
    Eastern Iowa
    Quote Originally Posted by JohnnyNitrous View Post
    I think the duramax would work better.... the cummins would have a single stack and you wouldn't have to worry about melting the heads on the duramax as the river water would keep it nice and cool.
