[Event] Parker race
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 102
Parker race
    Senior Member AJDEAN955's Avatar
    Aug 2011
    L.A.
    Default Parker race
    Who's coming out?
    JUST A KID IN THIS OLD MANS WORLD......
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    You know iam there with the 177 boat
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    031 RIVER4FUN's Avatar
    The 031 is in. M/E
    Member 00 CP's Avatar
    May 2013
    Fallbrook, CA
    Default When?
    What are the dates?
    Aug 2011
    L.A.
    February 21 22 23
    Jul 2009
    AJ are you running your boat? Everywhere I look I've seen you cant run a blown v-bottom. Just curious if, then how?
    Junior Member El Segundo's Avatar
    Oct 2013
    Mi and mi amigos weel be thare. I nead som new Burros and I theenk thay leev at thee Reever.
    I weel cotch sum for me! Afetar, I hope I cane see thee raecing!
    "We keep only the best beans for ourselves, and the rest, we sell to someone else."
    Aug 2011
    L.A.
    Quote Originally Posted by Psycotic Break View Post
    Yea Iam running mine that rule is not for a semi v like mine it's for more of a deep v cruiser I was told, the guy Jeremy who runs the whole adba deal said I won't have a problem
    Jul 2009
    Quote Originally Posted by AJDEAN955 View Post
    Awesome news. Good luck and be safe
    Aug 2011
    L.A.
    Will do thanks!
    Senior Member bp298's Avatar
    LHC
    has nothing to do with the depth of a v bottom. here's the rule.
    3.3.1d Hulls - Any hull design is acceptable with the exception that no blown engines will be permitted in any Sportsman class jet boat with a V-bottom.
    this rule applies to any v bottom. sportsmen classes, for rule purposes, are considered QE, PE, and TE. which means, you are legal to run RR, SE, or ME. but not TE and above.
    here's a link to the rule book. http://www.lucasoildragboats.com/pdf...ok_Revised.pdf
    San Diego, CA
    Might want to check that wording.... I don't see where its only for QE,PE,TE only. By definition of the rule book, QE, PE, TE, ME, SE are all Sportsman classes. RR is not on there.
    3.1.1e Hulls - Any hull design is acceptable with the exception that no blown engines will be permitted in any Professional class jet boat with a V-bottom.
    3.1 Professional Classes
    All Professional Class boats must use a drivers capsule, manufactured by a SFI Certified Manufacturer
    TFH TOP FUEL HYDRO 1000 ft-dual prop only
    TAH TOP ALCOHOL HYDRO 1000 ft
    TAF TOP ALCOHOL FLAT 1000 ft
    PM PRO MODIFIED 7.00 – 7.99
    3.2 Sportsman Classes (Brackets)
    PE PRO ELIMINATOR 8:00 - 8:99
    QE QUICK ELIMNIATOR 6:00 – 6.99 (1000 ft)
    TE TOP ELIMINATOR 9:00 - 9:99
    ME MODIFIED ELIMINATOR 10:00 - 10:99
    SE STOCK ELIMINATOR 11:00 - 11:99
    Boat 405.
    Member Juan Valdez's Avatar
    Jul 2012
    Corona Hills, Ca
    valdez is coming.
    LHC
    several years ago, for reasons I won't get in to, sportsmen classes were divided into sportsman and brackets in the rules. brackets being rr, se, and me. sportsmen being te and pe (and subsequently, qe). for more reasons, there was an effort to eliminate this discrimination a couple three years ago.
    in the previous rules, this rule had been revised based on the rules division between sportsmen and brackets. i.e., it did not apply to the brackets (rr, se, me). the -intent- never changed with respect to this rule when things were changed back again to all open boats being sportsmen.
    this rule has been around for a long long time, and it's never really changed. blown v bottoms are ok for rr, se, me. not for te and above. I realize (and you are correct), the current language does not reflect that. but it was, and will continue to be, intent.
    it's also understood that many many years ago, blown v-bottom's ran in classes quicker than me. not disputing, or trying to justify the rule. just saying, this is what it is and what will be enforced in lucas. and again, I agree there needs to be a revision for clarification.
