Fuel system remodel
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 44
Fuel system remodel
    Glendale Arizona
    Default Fuel system remodel
    The old guys are going "I thought that guy was dead". The new guys are going "who the F is this"?
    Looking to upgrade fuel system this year. Stick drawing and a couple photos of my exisiting setup (for what it's worth) and looking for ideas on how to plumb the new pieces/parts.
    Existing is a Holley fuel pump split to two regulators one for the motor and one for a 200 hp plate system.
    -8 from tanks to pump. -8 from pump to a T. -8 from the T to the fuel side regulator and -6 to the nitrous. Nitrous side goes to a -3 T and to the plates. The motor side goes -8 to the regulator then -6 to carbs (single inlet 660's).
    New stuff is a bigger/better Clay Smith fuel pump (more pressure and volume) and two new Holley 750 mech sec DP carbs so dual inlet. Figure on going -8 from the pump to some sort of distribution block and split off X 4 -8s to the new dual inlet carbs, then one -6 to feed the regulator on the nitrous side. I'm not looking to break the bank or build the ultimate fuel system here. Want each side (motor and nitrous) on it's own regulator and all fed via the one mech pump.
    Ideally would like to do this with the one pump, two regulators and some sort of distribution block.
    Thanks in advance. I'm a visual kind of guy so pictures are great.
Name:	IMG_0035 (Medium).jpg
Name:	IMG_0036 (Medium).jpg
Name:	IMG_0037 (Medium).jpg
    Holy hell who's this guy...
    Feb 2009
    MANTECA
    Ditch the fram fuel filter they don't flow much at all.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    ditch the holley regs too and get a good 4 port reg that allows to feed all four bowls. also allows for a mechanical fuel psi gauge inlet that you can go remote with and mount anyplace you want.
    Senior Member LOLYFE's Avatar
    Idaho
    Heard this about twenty years ago, "the only thing a good fuel system hurts is your wallet"
    Glendale Arizona
    Quote Originally Posted by ptc View Post
    See...............that's what I'm talking about. I see it's BG. Have you got a part number on that little beauty? Found it. It's just what I was looking for.........until I saw the price. $452 for a regulator????????? Gonna have to figure out another way.
    Senior Member Rivieraracing's Avatar
    Jul 2012
    Oregon
    That regulator is awesome!
    Glendale Arizona
    Quote Originally Posted by LOLYFE View Post
    Said the guy selling the overpriced components.
    Come on..........$452 for a regulator. That's just crazy.
    Senior Member brgrcru's Avatar
    Montrose
    Magna fuel for a little over $200 4 port reg.
    Q.C./Big River
    That was probably the guy selling the overpriced components that said that.
    WOW! Bout time Dude. I think you are gonna be pleasantly surprised. Those old 660's have done the job well but the 750's are really gonna make a difference. While you are upgrading you should really put the nitrous on its own system, own pump and regulator. Magnafuel has a really nice one very similar for less than half. I think Joey has the one I am referring to on his boat. Use the magnafuel for the carbs and use a holley bypass for the nitrous and plumb the return back to a "T" on the fuel pump inlet.
    EDIT: Also I would ditch the Fram filter as mentioned. Use a Mercury water fuel seperator and an in line screen filter from Magnafuel or aeromotive or something of similar quality.
    Good to see ya back Dan! Summer can't get here soon enough.
    Senior Member Futs's Avatar
    Orange CA, Big River
    I have a spare one Dan. Needs a new diaphragm, but other than that its good to go...
    Dan.
    you have -3 line for the fuel line on your nos plate system?
    Do u have 1 fuel and 1 Nos solinoid that splits off for both plates or does each plate have there own nos and fuel solinoids?
    x2, could not agree more Dennis!
    Silverdale, Washington
    How the hell did Danny end up with 2200+ posts on here? Did he get to bridge his posts from Hotboat? Nice to see you posting up Dan. Welcome back......john
