aluminium amphibian5600# with jet drive
Results 1 to 1 of 1
    Jan 2014
    Default aluminium amphibian5600# with jet drive
    That old saying " I maybe crazy but i am not stupid" (does not apply with this obsession) I have started to build an aluminium amphibious vehicle 20 ft X8Ft (SUV style)) 5600#using a 350 power glide to power a dana 18 transfer case to shift between rear axle or jet drive.the case is on end ,turning in reverse(HOWL ? gear Co. says it will stand up OK) will try to insulate a cover for noise? the wheels are in the outboard sponsons with fender skirts, wheel retraction to be engineer ,any ideas? thought of air bags to lift a arms and rear swing axles on independent rear end , i think i saw this done?
ID:	471857   Click image for larger version.
ID:	471865   Click image for larger version.
ID:	471873   Click image for larger version.
ID:	471881   Click image for larger version.
