rocker bottom hull jet drive
    Jan 2014
    Default rocker bottom hull jet drive
    I am building an amphibious vehicle (aluminium hull 20 ftX8ft. at Gvw5500#the null is 6* degree dead rise there is a slight rocker in keel about3 degrees. boston whaler or sea sled type hull with wheels in outboard sponsons. is a 350 chev /powerglide .powering an american turbine up to it? how do jet drive perform at lower speeds.gas consumption? or will it plane? do i have to always get it up on a plane? need estimate on planing speed, rpm and h.p.?
ID:	475010   Click image for larger version.
ID:	475018   Click image for larger version.
ID:	475026   Click image for larger version.
    Dec 2010
    Sapulpa ok
    Ok I'll bite... If it does plain it will drink a bunch of fuel. I would worry about it stuffing a wave. 400 hp just to break plain if you can keep the pump hooked up. Just a guess. Weight dist ect... ect... I think it's a neat deal keep us posted !!
    Jan 2014
    Default amphibian SUV.
    Quote Originally Posted by piston in the wind View Post
    was told by american turbine sales that a 350 (250+ hp) should push it 5500# gvw what is stuffing a wave?. do not know if the jet impeller can be changed to get more push?
    [email protected]
    Ohio
    Stuffing a wave is when the bow of the boat goes through the wave instead of over it. With the weight you're talking and the power, I think it will move, but not enough to plan. The amphibious 770 of the '50s did 70mph on land and 7 on the water. I like the idea you're going with. Make a boat into an amphibious. Keep us posted.
    Tim
