Small block impeller size and rpm
Results 1 to 14 of 14
    Member McIntyreBahner's Avatar
    Apr 2010
    Norco,ca.
    Default Small block impeller size and rpm
    If you are running a small block i was wondering what size impeller are you running and at what rpm? I put a 421 ci sbc in my Daytona and would like to see what combinations others have tried. Thanks.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Where does the engine make peak power? That is the key to knowing what to run.
    Apr 2010
    Norco,ca.
    Default Peak power
    I have never had it on a dyno. In the jeep it would pull hard to about 6800 before you could feel it lay over.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by McIntyreBahner View Post
    Yeah buddy! I want to see you saw off adam with that deal!
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Oct 2012
    Just found out that my blade is an A- cut and my 350 with 671 blower is spinning it to 5400rpm. Prior to fitting the blown motor a healthy 350 nothin fancy just flat tops and a good cam was spinning the same blade to 4200rpm.
    Spooling Sideways S13's Avatar
    Jan 2014
    Hermann, MO
    Im running an aggressor bronze B impellor with my 5.3L LS motor. Runs 4600rpm at 65mph with new wear ring and new 9 vane bowl. Estimated 375hp.
    Ran a C minus in our SBC (zz4 & 2nd motors) 16' Allusion Tunnel, turned it just under 6K.. 80/85 mph
    Apr 2010
    Norco,ca.
    I ran this motor in my Bahner with a bronze B. It spun 5600 @ 87 mph. I now have a SS BC impeller in the Daytona. Wanting to find a combo to spin it at least 6500.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Quote Originally Posted by jyeager View Post
    Only thing ur guna be seeing is both of our transums jake.
    Ur launch will suck but a c- is in ur future Jeff
    Quote Originally Posted by HBInHeat View Post
    Ouch.
    At least his has been running for the last two years.
    Nov 2009
    I have a Legend "C" you can try out if ya want.
    Sep 2010
    Ouch.
    Exactly, we will see if it will even come out to play this summer.
    Surprise, AZ
    I run a 377 sbc spinning a detailed SS B- , inducer and stuffer to 5500 on the motor. Low 80's.
