[Question] Show me your linkage and fuel line setup.
Results 1 to 14 of 21
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default Show me your linkage and fuel line setup.
    THINKING about switching from a pair of inline 450's to a set of 600dp's for my new motor.
    Problem is, I have no clue how to set up the linkage or fuel lines, since these things have to sit sideways.
    I am way out of the loop here.
    Please show me yours, and tell me what you have and where you got it.
    I am always on the road and just don't have the opportunity to hang out in speed shops like I did 20 years ago.
    100 years from now, none of this will matter.
    Here's a couple links showing the most common way to do dual carbs. You can usually find a lot of these parts used if you ask around.
    http://www.summitracing.com/parts/edl-7071/overview/
    Polished Aluminum Supercharger Fuel Line & Log Kit - CP Performance
    Derby, Kansas
    Well here's mine.
ID:	480786   Click image for larger version.
ID:	480794   Click image for larger version.
ID:	480802   Click image for larger version.
ID:	480810   Click image for larger version.
    I use hard line from the carbs to a (t) fitting, then I made my own fuel rail, not the best but it will work, its -8 from the pump then goes to -6 at the first (t) fitting.
    I bought my carb linkage from Jegs., its the same setup as the post above mine.
    Mar 2010
    Clarksville, TN
    There was a kit in the parts sale thread
    One from last year I'll find the pic of the other side too...
    Mar 2010
    Modesto, Ca.
    Wow that is some nice stuff.
    Everyone's boats are so much sexier than mine...
    Sep 2011
    Carnivalride where did I you get that bracket between the carbs like that?
    Derby, Kansas
    Quote Originally Posted by 525SC777 View Post
    I made it.
    Sep 2011
    A friend of mine has one too, his is for dominator carbs not sure how close they are? Do you have a scanner that you could trace it and email it to me?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    This is the same engine. One pic with the bypass in the return line in view and one at an electric pump outlet returning to the tank.
ID:	482130   Click image for larger version.
Name:	van 8-28-08.JPG
    QE 439 Twin Turbo
    Mar 2010
    Modesto, Ca.
    It turns out I have to run these carbs inline, and with the 10 3/4" center to center spacing, they will be pretty much touching each other. I have no idea how to plumb this.
    Anyone have a good pic of a pair of 650 DP dual feed carbs inline with all the plumbing?
    Jul 2013
    OR
    I bought both of these from ebay and all my an fittings from Red Horse. Came out nice for running the carbs Pro Style. Linkage was a little tricky to get fine tuned but very clean once it's all dialed.
    Mar 2010
    Modesto, Ca.
    I have to run them inline, not at 90 degrees.
    I think I have it figured out....maybe.
    Pair of these, inlets pointed away from each other---into 90* fittings----into a Y----to the pump.
    http://www.summitracing.com/parts/rus-641090/overview/
    It's all over the place, but should work.
    I have to slot the base plate holes too, because the carbs hit each other in the middle by about 1/8".
