BBC Exhaust port size
    Aug 2012
    Default BBC Exhaust port size
    Trying to locate header gaskets for my 454/log manifold set up. Heads are 049's "oval" (square) port. I can find gaskets that are
    1.85 x 1.90 or 1.88 x 1.88. I can't find any tech data that tells me what I've got and I sure as hell can't measure worth a damn. Well, I can measure but the conversion fogs...I come up with something between 1 14/16 - 1 15/16 but the online calculator just rounds up/down Sure appreciate a little help.
    Senior Member Mohavekid's Avatar
    Penn Valley, The Sierra Foothills
    No need for a gasket on logs.
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by 1320 View Post
    1 14/16 = 1.875
    1 15/16 = 1.9375
    Hope this helps..
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Aug 2012
    Quote Originally Posted by 2002CP19 View Post
    1 14/16 = 1.875
    1 15/16 = 1.9375
    Hope this helps..
    Thank you very much.
