I know im going to get hell for this cuz im new here
Results 1 to 14 of 28
    Feb 2014
    Default I know im going to get hell for this cuz im new here
    Here we go anyway anyone running or know of any 500 inch cadillac jet boats
    I have seen the sprint boats but never a day to day on the lake boat
    befor you slam me i know about the valve trouble with high rpms on STOCK motors.
    I also searched and came up with nothing
    San Diego, CA
    Quote Originally Posted by hippy killer View Post
    Not exactly a common motor for jet boats.
    Boat 405.
    The 500" Caddie is one of my favorite motors. I have built 5-6 for bracket cars and they all kicked butt. Make a mild motor and put it in a light car and it last forever and kicks butt big time. I would conceder using one in a boat but I think all of the accessories would be hard to come by. I have never looked but I would bet they are.
    Member 5ribsangerhydro's Avatar
    Jul 2013
    south central pa
    There was a guy that ran one in a jet, name was Sculley Alley jr (sp)
    he ran Stock eliminator I think,... he was always at Augusta .
    I have not seen him in the last 3 years
    not the cleanest boat, but he always made the final round
    Thumbs up
    If you have fab skills go for it!! Im sure a header company can build some upswept headers for it.schoenfeld in arkansas cld build the headers. pto to jetpump is gna be tuff to get tho.wonder if a vdrive pto exists for them that cld be machined for 1310 driveshaft?
    El Cajon, Ca.
    There used to be a guy back in the late 80's-early 90's that tried to run a 500 Caddy in a TAD... and not as a novelty, but tried to be competitive. I don't recall his name, but he was from Minnesota or Wisconsin... one of those "locked in for the winter" places that breeds crazy guys.
    The bellhousing should be the same as the Olds/Pontiac/Buick... not sure about the front though. Headers will be a bit of a pain seeing that almost nothing else will share the same pattern. It would be a fabricator's fun project... torque like crazy... but much of the downsides you find with the Olds, you'll find ten fold with the Caddy. Not a bad engine per-se... just at that point... why not a 6.2 GM diesel if you want big, heavy, and weird?
    The Bostick®
    Not cool bostick!! I have a place in my heart for the 6.2 & 6.5 engines man, i was a gm commission tech when they came out and they provided me the down payment for my 1st home as well as payin for my 1st jet lmao
    dare to be different .
    does anyone make a good intake ?
    Price Motorsports makes these adapters for a Ford intake:
    AP-23 Intake Adapter Kit
    Jun 2010
    Aguila, AZ
    FYI... Big Block Chevy exhaust spacing is very close to the Caddy. You can cut the flanges off a set of BBC headers and spread them a bit and weld them to Caddy exhaust flanges which are readily available. I did this when I installed a 500 Caddy in a Ford van so I know it works.
    Shirl
    CJ60
    Senior Member sammyc57's Avatar
    Sep 2010
    Broken Bow,OK
    Quote Originally Posted by MrEracer View Post
    Shirl
    CJ60
    all that work for a ford van? to each his own I guess. deff. differnt
    Feb 2014
    just at that point... why not a 6.2 GM diesel if you want big, heavy, and weird?[/QUOTE]
    caddy motors are not heavy with an aftermarket intake the way LESS than a small block chevy
    the pto from the olds is the same really only trouble is the starter
    ill put up spme pic later going to do this in a 72 sidewinder 16 footer boats a long way of cutting the stringers out today
    Sep 2009
    Default I Know I'm going to get hell for this
    Fellow up here in Canada ran 500 Cadillac in commercial aluminum boat hooked to 2 Berkeley pumps. When he finally wore out the Cadillac he installed a 502 B/B, turned exact same rpm, no better, no worse.
    Jun 2010
    Aguila, AZ
    Quote Originally Posted by sammyc57 View Post
    It wasn't much work at all... I got the motor and turbo 400 for $300 and had it installed with no cutting or welding. I needed a work truck that would tow a heavy load and the Caddy sure worked out better than the 351 that was in there.
    I took it to the high school drags one night and none of the ricers wanted to race me (not cool enough)... Well, after I cleaned the first one they all got in line to race me and I beat every one. I had a cheering section at the line and my wife said they erupted in cheers every time I got the win light... It ran 14.8 at 88 mph, enough to smoke the Honda's.. I will say that some of them should have beat me but they didn't know how to anticipate the lights... I heard some of them looking the van over muttering 'who is that old guy?" They didn't know about the 500 Caddy, Edlebrock, 850 Holley, headers and cheaters on the back... If they'd asked, I'da told em...
    Shirl
    Senior Member RogerThat99's Avatar
    Aug 2010
    I don't know if this is a 500 or not, and it is in a v-drive and not a jet. The boat runs good. The red & white Bristol in the background of the 2nd pic has a Caddy in it also (v-drive).
ID:	488218   Click image for larger version.
    "I Love Haters" - Its not a frame of mind for us...IT'S A LIFE STYLE!!!
    http://www.performanceboats.com/signaturepics/sigpic17778_1.gif
