Sta-bil and race fuel
Results 1 to 11 of 11
    Tim
    Tim is offline
    Senior Member Tim's Avatar
    Hangtown, Ca
    Default Sta-bil and race fuel
    Any benifits?
    San Diego, CA
    Be sure to keep your race fuel in a sealed container made of steel. It's good for about a year sealed up from what I've heard. I put dates on all my cans when I buy them so I know how long they have sat since I bought them. I only buy the 5 gal cans at a time. I bought a 55 once and didn't go through it fast enough. The river boat gets 91 and gas stabilizer at the end of the season.
    Boat 405.
    Senior Member bc18's Avatar
    Also to add to this it's a good idea to elevate them slightly so air passes through the bottom instead of setting them down on concrete
    Mar 2010
    Clarksville, TN
    The guy I get mine from says its good for 2 years. VP 110
    I bought 55 also and I won't do that again. I think 35 will last a race season.
    Senior Member bp298's Avatar
    LHC
    i've been buying by the drum for 10 years and never had a problem. key is keeping them tightly sealed. for use, i use 5 gallon cans with drum bungs, so they are sealed tight as well. the 5 gallon cans with the plastic pour snout and little plastic cap don't seal all that well, just imo.
    i've had race fuel suppliers tell me drums/cans will last indefinately if effectively sealed. not so sure about that, but not going back to hunting down 5 gallons at a time.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Sealed steel drum for storage.
    Anything in the boat I would write off as don't trust to perform.
    QE 439 Twin Turbo
    Mar 2010
    Clarksville, TN
    When I get home from a race I pour the unused fuel from the jugs back in the drum and most of the time there is very little left in my fuel cell. And like Brad said get the barrel off the ground, I just set mine on a few cut 2x4s. I hadn't messed with it that much so I was just gonna start getting enough to last a season. I won't burn 55 gal in a year, might burn 5 gal at a race. But I will always store it in a drum.
    LHC
    5 gallons? dude, you need to start makin some rounds. maybe go do some testing... a drum will last me about a year, +/-.
    i've always set my drums on 2x4s. and have my 5 gallon mini-drums sitting off the ground. when i get home, just disconnect the hose at the pressure regulator, pump the fuel left in the tank into an empty mini-drum.
    Mar 2010
    Clarksville, TN
    I run all they will let me run BP
    Hope I'll get to run some more rounds on Sundays this season
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    I buy VP fuel in 5 gallon sealed pales.Fuel won't last in drums very long in the heat.I take at least 3 pales to every race.
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Butane is added to fuel to determine vapor pressure. That's why the tight seal is so important.
