Thinking of going from jacuzzi to berk 12jc
Results 1 to 12 of 12
    Senior Member crf311's Avatar
    Meraux, LA
    Default Thinking of going from jacuzzi to berk 12jc
    Pump. How hard is this swap to do? Will I need to do any glass work? I have a worn out Jacuzzi WJ - B in my jet now. I just picked up a Berkley 12JC-A . Both pumps have a place diverter. My motor is a BBC with about 450 -500 HP. Thanks
    Senior Member 71kona's Avatar
    have fun
    this boat will be the death of me
    The "cut out" for the Wj (existing hole) is slightly smaller than the Berk intake size , so the swap is fairly straight forward . Steer cable should work , fwd reverse will not (33 vs 43 series needed ) The Berk "A" should work well with your motor to start . Call or post or Email if we can help we have pics and tutorials if you need help Tom
    blown mopar moparjet's Avatar
    manassas,va
    i thought that the jacuzzi hole was bigger than a berk....sh/t i wuold have swapped a long time ago
    throw it in reverse
    Clovis, Cali
    Quote Originally Posted by moparjet View Post
    Jacuzzi YJ is bigger, but as Tom said the WJ is slightly smaller.
    Quote Originally Posted by propless View Post
    The YJ is sooooo Big you have to tie a Two by Four to your A$$ to keep from falling thru BUT we have a fix for that too! that said yep the WJ to Berk is a "shoe in" (hmmmm get it shoe ...) oh well weve done them all anybody needs help call or post Tom
    Hey Proppy Next weekend 35 &26 at SA north shore , Beer, BBQ & Model /Babes (on decks/photo/shoot etc) you in ?? Anyone else interested lemme know
    Las Vegas, Nv
    I did a Jacuzzi to Berk swap. Like Tom said hole is smaller,so all is required is a little trim and fill some holes,if locating in the stock location. I did a set back,therefore I glassed in the entire hole and then recut the hole,just becouse I did not want to have to add a piece of metal to close up the front part of the hole. I'd say the hardest thing is pulling the intake and even that is not that hard.
    If You do do it and have ever considered doing a set back ,now would be the time to do it.
    Don't go scaring off all the Red fish and Specled trout in Bayou Bevenue Ya Here!....HAl
    Meraux, LA
    Thanks all, I'm still kicking this project around. Not sure what I'm feeling up to at this minute. Life's been a little crazy around here the past few years.
    Meraux, LA
    Thanks for the info. Funny you bring up the fishing on the bayou, They have been knocking them out from the banks. My brother in law filled up an 96 qt. ice chest in 1 hour today at lunch. Guess what's for dinner?
    Las Vegas, Nv
    Quote Originally Posted by crf311 View Post
    Red Fish on the Grill!
    Man I do miss fishing in the Marsh!....Hal
    Meraux, LA
    You know it. With some Tony's for the spices. How long you been away?
    Parker Az. / Burley Id.
    I have seen several YJ swaps to berkley with and adapter plate. I know Brad at River Speed and Sport in Blythe Ca. has done a few and had a template for the adapter at one time. His work # is 760-922-6868
