Suction Housing Seal
Results 1 to 5 of 5
    OU812 Member mel87901's Avatar
    Nov 2011
    Default Suction Housing Seal
    Hello. I am looking for cross number for rear inter bearing seal on a Berkeley suction housing. I have Berkeley number but cant find cross for it. 150-s 14380. Looking for timkin or national or ? Trying to get local. Thanx for any help. Mel
    You may be able to source it or cross reference it locally by dimensions in an industrial or automotive application , however the correct seals are Clipper type JM/Parker hard rubber (flexible aramid fiber reinforced composite casing) with stainless spring rings, pm sent Tom
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Give any industrial seal or bearing house a call. All you need is the housing bore ID and shaft OD.
    QE 439 Twin Turbo
    Jun 2013
    In our business(big-rig tank trucks)We run into this type of situation a lot(where we can save money and get an equivalent part cheaper locally). After 25 years the best advise I can offer is; unless you need to buy 10 of these and/or your time is not worth much, just call Tom @ JBP and in a few days you have THE CORRECT PART.
    just my .02cents, but I've been purchasing stuff like this for a $8million a year retail company(it's all we do) and unless you plan on buying them often, it's not usually worth the time or potential headache.
    Nov 2011
    Default seal
    Thank you Tom. Your the man. Got that seal yesterday and will get it going this weekend. I need a few more little things. I will give you a call this week. Thank you again . Mel
