B hi-helix ?
Results 1 to 8 of 8
B hi-helix ?
    Jan 2013
    Default B hi-helix ?
    I am turning a A hi-helix at 5500 rpm, changing induction system, want to get motor rpm up to 6200-6300. according to a B HI-HELIX hp. chart I would be at the 6200 mark. can I get my A cut down with no ill effects or do I need to buy a B impeller ??
    Senior Member Futs's Avatar
    Orange CA, Big River
    you can get it cut. Where does it make peak power?
    San Diego, CA
    Quote Originally Posted by eric tx20 View Post
    Try impeller after you have made your motor changes. See what rpm it turns, then cut it down if needed.
    Boat 405.
    Member Juan Valdez's Avatar
    Jul 2012
    Corona Hills, Ca
    Cutting it down to a "B" will only give you like 200 more rpm.
    Shell Knob, MO
    Quote Originally Posted by Juan Valdez View Post
    Unless you gain some HP by doing it. Then it would pick up more than 200 RPM. (and I think it will).
    Like said above; try it with the new induction set up and then decide what to do.
    And in answer to your original question, yes, it can be cut without any ill effects.
    Jan 2013
    my peak tq is at 5500 and peak hp is 6500 and according to the A and B hp & tq chart it should put me at 6100 t 6200 before any gains. glad to know I can just get mine cut down. thanks for te help
    Jan 2013
    Duane, I will see what it does when I get it running then I will get with you to get it cut
    Shell Knob, MO
    Sounds good!
