exhaust
Results 1 to 14 of 15
exhaust
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default exhaust
    I have a stock 454 with the standard Hardin marine log style exhaust manifolds. I have the 2 7/8" exhaust tips. If I cut the flange of the riser off, I will be able to use 3 1/2" exhaust hose. I will also be able to use 3 1/2" SS exhaust tips. I can also use Imco 3 1/2" mini mufflers. I can also do the same thing in a 4" hose, SS tips, and mufflers. Which would you do? I can't afford headers. Has anyone done this before? Did you gain anymore performance? I know it would sure sound better. Is it worth the time and effort? Thanks Kimball
    El Cajon , Ca
    $80 with free shipping!! 3 1/2 inch new!!
ID:	22907   Click image for larger version.
ID:	22908   Click image for larger version.
    Newton Ks.
    Take marc's, then buy a set of Lightning headers.
    I bought USED Lightnings, and those tips, and found 50HP/200RPM, but my cam and intake were no longer stock already.
    H.L. Mencken
    Junior Member Old Guy's Avatar
    SW Michigan
    Quote Originally Posted by cole ss View Post
    It's hard to see but I cut the ends off my snails so that I can use 3 1/2" hose. The tips have 3 1/2" in and 4" out with mufflers. Don't know if I gained anything....it just seemed like a good thing to do. All of the inside passages are 3" so I figured that I might gain a bit.
    I have a friend with a Dyno. We spent a lot of time and $$$ trying to find a way to compensate for the log exhaust system. You can't. I can supply all the details if you want them.
    El Cajon, CA.
    Quote Originally Posted by Marcsrollin View Post
    I saw these yesterday in person and they are waaaayyyyy better than the pics show, they are very very nice pieces!
    Rochester, wa.
    Hello, can you give me measurements of the tips? Inside, outside, and diameter of th flange. Thanks, Kimball
    El Cajon , Ca
    Sure , but they area at home and I don't get off work till 7pm.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    when my cole was stocker i found 100 rpms with that trick
    Rochester, wa.
    Thanks,did you go with 3 1/2" or 4"? Also did you us any kind of in line muffler? Kmball
    El Cajon , Ca
    I am running 4 inch. And no I never used any kind of muffler. I'll be home in about 30 minutes , I'll get you the measurements then!
    My first boat I had logs, 3 inch riser discharges. I put in 4 inch REX tips with built in flappers. I bought 1/2 foot of 3" hose, 1/2 foot of 3 1/2" hose, and 3 foot of 4" hose. I cut the 1/2 foot hoses in half, making them 3" in length. I then slipped them inside on another, 3 1/2" inside the 4", and the 3" inside of the 3 1/2" hose. These were glued in place, so they stayed put. I was my poor boy 3" to 4" adapters. Can't say there was much performance gain, motor was dam healthy as it was. But it sure made it sound a lot better, and quite a bit louder. I could run any slip in muffler, or clamp on muffler I pleased, with the 4 " tips.
    El Cajon , Ca
    Alright , the part that goes through and into the hull is 5 inches long. The top of the the cut chromed side is 5 1/4 and the under of the chromed side is 1 3/4. They also have the internal rubber flappers. These are new from CP performance and have never been used or installed in a boat!! They are 3 1/2 inch , and like Rod stated the pictures don't do them justice!
    Gas Dock Greg 75 spectra v-drive's Avatar
    Agoura Hills
    I did that when I had the Olds, worth the time just for the sound IMHO
    Member 07liberator's Avatar
    May 2012
    Monroe, Ohio, United States
    Default Stlll have the tips
    Are the tips still available ,Jeff 513-307-3052
