Comp Cams Xtreme Marine XM278H
Results 1 to 6 of 6
    Default Comp Cams Xtreme Marine XM278H
    Anyone in the 9.5:1 comp ratio range run one of these cams? If so, what brand of impeller and cut are you running and what's your max RPM with said impeller cut?
    Morgan Hill
    XM 278 H and 7.2:1 rollers in a 468 BBC open chamber ported ovals, 10.5:1, 850 double pumper, MSD, Headers....Runs to 4900 RPM with a tight (read loader and stuffer on a fresh pump) alum. A 19 foot jet at sea level for me, timed straight up...
    GT
    GT
    Senior Member wolfie's Avatar
    XM278 with roller rockers 10.5:1 comp 750 DP. I did it late in the season (after a valve spring gave way) so I've only had it out a couple of times since. I had backed down the timing until everything was broken in. I was running about 4800 RPM. We're at 4500' altitude. It was the most responsive the engine had ever been. I'm wondering if I'm a little under carbed at 750. I might have to see about an 850.
    Senior Member 78Southwind's Avatar
    467 Chevy 9.6:1 with XM278H, 830 Holley & 1" Carb Spacer, Air Gap intake, Edelbrock Marine 61459 Heads, Roller Rocker Arms 1.7 7/16. 5100 RPM with an A going to an AB looking for 5300 to 5400 RPM
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    how was the drive home Jerry glad to see the river disappear in the rear view
    Quote Originally Posted by 78CoLeBBF View Post
    It wasn't a bad drive home Lisa had someone to listen to her (Shelly). See ya in Parker.
