Installing Helmet restraints
Results 1 to 13 of 13
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Installing Helmet restraints
    ok, so it looks like i need to drill into the helmet and install these things. Talking to kent it he said on the sides i should do it just below where the chin straps are and then follow that back to the rear. On the front just below the vents. There's not much room to work with in the front on this helmet. He said i need to pull out some of the foam to bolt it up and then glue it back in. Any of you guys have any advice/recommendations on this or have some pics of this process. I want to make sure i do this right the first time!
    Speedy Member Jetboatguru's Avatar
    You want to ask Pro Gas Chet to post pics of his setup
    Quote Originally Posted by hondo jim View Post
    get a life..... mowe some more lawns. pick up some cans, save your ol ladys welfare checks and get your teeth fixed.
    pictures boat parts
    San Clemente, Ca
    Quote Originally Posted by Jetboatguru View Post
    lol, thanks.
    San Clemente, Ca
    Hoping for more input on this before i go drilling holes into my helmet... ask twice, drill once
    As much as I would have liked to use double sided tape to stick mine to avoid drilling my expensive brain bucket, I had to drill it and you also have to tear back the padding to get the nuts on. It sounds like you are on the right track.
    Cy
    Mohave Valley/Quartzsite
    Shaun, Hope this helps. I circled the area where I drilled the holes. Not sure if this helps.
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    San Clemente, Ca
    stix818, thanks thats exactly what i was looking for. I wasnt sure if i should drill that low on the helmet, on the sides i can move up a bit but on the front i either can drill way at the bottom or way up top.
    Right on!! I see what your talking about with the front. I personally think you would be okay just below the vents in the front. Good luck!! Are you trying for Phoenix next month??
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    San Clemente, Ca
    No, when the njba opens back up will be my first race unless somthing local pops up.
    Parker Az. / Burley Id.
    I have done a few. On the inside I use about a 5/8" roto broach ( looks like a baby hole saw) and it makes a nice clean hole in the foam. Then the washer and lock nut are counter sunk real well and the inner material covers over the hole.
    San Clemente, Ca
    All done, kind of trippy pulling a helmet apart like this, I had this one down to just the shell! There really doesnt seam to be all that much to these things. Some foam, some padding, and hotglue.
    I am glad i pulled it all the way apart though, they really dont do all that great of a job glueing in the cloth/padding. I took the hot glue gun and glued down every peice of loose cloth i could find. Should make it stay put a bit longer.
    Chantilly Va.
    Default Restraints
    Shaun,except that one side is a little off center than the other ,You have them where they need to be.They will pass Tech..they are GOOD TO GO.Have fun racing next year!!! EDIT...After looking at the photos, The neck strap threw me off...Looking better than I thought...You Go Shaun!!!
    San Clemente, Ca
    Quote Originally Posted by sunkisst View Post
    I attempted to line them up with the neck strap bolts using and straight edge with the 90* elbow. Not any flat surfaces to press it up against but each side should be the same The rear one i think i got a hair off to the left, but it's just bearly off.
