Where to buy a replacement one of these?
Results 1 to 14 of 14
    Aug 2012
    Default Where to buy a replacement one of these?
    Mechanical fuel pump to carb fuel line
    Make one or just go an/hose. Try napa either way for a quick fix.
    Made In The Shade
    Custom Window Tinting
    Aug 2012
    Thank you
    Jul 2013
    OR
    Whats wrong with that one other than the finish? A can of mexi-chrome and you're back in bizz
    Aug 2012
    Quote Originally Posted by 79witchcraft View Post
    I got this...
    Aug 2012
    Should I use tape to hold the finish on?
    Although not likley chromed , Napa or Oreillys should have a similar line (+ or- length) with the same type flare fittings for a couple bucks ...
    Jul 2013
    OR
    Now you're talking! Tin foil would of been good to ya know
    Default line
    I have 2 of them, nice chrome. 1 is 1 1/2 in. longer to the first bend on fuel pump side.
    Aug 2012
    Quote Originally Posted by Jim Brock View Post
    You just rubbing it in or are they for sale?!
    Aug 2012
    I need that for the antenna....
    Default line
    for sale, 15.00 each
    Senior Member Mouzer's Avatar
    corona ca
    i would grab those from mr jim brock,,he is giveing you a good deal there
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Aug 2012
    PM sent...thank you Jim.
