Top mount starter help
Results 1 to 9 of 9
    Member BergerDirn171's Avatar
    Nov 2011
    Edgewood,NM
    Default Top mount starter help
    Hello,
    I was wondering if anyone knows where to buy a new top mount starter like the one in my pictures. Three hole mount for BBC. Thank you for your help in advance!
ID:	500905   Click image for larger version.
    Quote Originally Posted by BergerDirn171 View Post
    Hello,
    That is an early Prestolite top mount RR deal , word of caution ,most common mistake is when a customer has a starter problem , takes that starter to Pep boys or Oriellys etc ? and they "match it up" ... when that "supplied starter" is installed suddenly theres a "no start" , the supplied starter actually will spin the engine backwards ... check your pms Tom
    The Right Coast/SE-PA
    That starter is a tank, I have one and it is worth it's weight.
    If you need it rebuilt take to a place that rebuilt starters. As mentioned above the wrong top mount will spin the engine the wrong way. It may look the same but it's a reverse spin.
    Again...that is a very good starter!
    Nov 2011
    Edgewood,NM
    I didn't realize it was such a good starter it was on the boat when I bought three years ago. It started dragging and barely starting even with a full battery. Ill watch out for the ones that spin that spin the wrong way. Thanks for the info!
    Senior Member wolfie's Avatar
    I bought a Hi-Torq top mount from Tommy for a good price. Worked a lot better than the Presto-Lite I had rebuilt a few times.
    Nov 2011
    Edgewood,NM
    Thanks for your help Tom! Check your PMs
    Nov 2011
    Edgewood,NM
    Quote Originally Posted by wolfie View Post
    O ok cool! I think that's what I am going end up going with.
    Member 07liberator's Avatar
    May 2012
    Monroe, Ohio, United States
    Hello,
    I have two of them your better off going with mini high torq
    May 2012
    Yes mine always would start cold but hardly ever when motor was hot it drug all the time and drained new bat.
    mini starter is your answer
