Tach not working...
Results 1 to 10 of 10
Tach not working...
    Member 88hardin's Avatar
    Apr 2012
    Default Tach not working...
    I just installed my new motor and and msd 6m with the soft touch rev limiter. The tach is no longer working and from the wiring diagram it shows the grey wire is the tach. The boat originally had the gm hei, did i miss something somewhere any input would be great.
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    Did you hook the tach up to the coil or the grey wire on the box?
    Apr 2012
    I hooked it to the grey wire on the box!
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    If you can't get the tach to work,I have a New Auto Meter memory tach for sale. 150.00.
    Surprise, AZ
    You probably need the tach adapter from msd.
    Jan 2013
    Magic Mountain CA
    Quote Originally Posted by 67weiman View Post
    What he said
    https://www.msdignition.com/products...tach_adapters/
    Senior Member BGMAN's Avatar
    What kind of tach is it?
    Apr 2012
    Quote Originally Posted by BGMAN View Post
    Its whatever kind came in a 1987 Eliminator Daytona. I dont think they have a name on them.
    That's what I was afraid of. You can try the tach adapter, but there is a chance it will still not work. Might have to look into a Autometer or something along those lines.
    Apr 2010
    Rocklin, Calif.
    Cool
    If you look in the instruction booklet there is a compality chart..thers your answer
