Help with rotted floor section
Results 1 to 10 of 10
    Member rick1964's Avatar
    Aug 2013
    San Diego Ca
    Default Help with rotted floor section
    Ok so Im almost afraid to ask, but I figure I better. I have this section of rotted floor under the front passenger seats of my 1970 19 foot Schuster jet boat. I've cut out the bad section which is 20.5 x 41.5 inches, with a couple inches left that I didtnt get, and my problem is, should I just cut across to just the next stringer or should I pull it from hull wall to hull wall and replace that whole section. What Im getting at is would I be better off leaving it alone and put the 20.5x41.5 inch piece of plywood in and glass over it, thereby covering up that little bit of rot that I didn't get just on the other side of the center stinger, which is still just under the seat frame, and would leaving the original floor in one piece under the driver seat front to rear alone, which would be better for strength? Im afraid to separate the plywood completely from front to rear for fear of introducing more twist in the hull. I was thinking that if I just fill the hole with 3/4 inch plywood and leave the rest alone that it would be better. Not too sure which way to go. This is the first time and Im determined to do everything myself. I figure I'll be back in it in 10 or 15 years to replace the whole floor anyway, and I'd like to see if I can get away with just patching it for now, because Im just not prepared to replace the whole floor. The rest seems in decent condition, no rot. I'll lightly glue the carpet in for now.
ID:	502505   Click image for larger version.
    Senior Member wolfie's Avatar
    If it were me, I'd replace the entire floor. A lot easier to do now since you've already started it. JMHO.
    Jan 2013
    Magic Mountain CA
    Based on what you wrote replacing the section would be fine and a lot easier. I don't believe the floor has much to do with the strength of the hull when I look at your picture.
    Now that I've said that here's my experience with a floor with a section that was rotting. I thought the rest was fine because it felt solid when in fact there was wet rotting wood in places I didn't expect to find it. I found it because I decided to replace the entire floor.
    If it's original it's 44 years old
    I redid my floor last year and gel coated it as well...opened up a ski locker and under seat storage.
    New floor install
    Made In The Shade
    Custom Window Tinting
    Aug 2013
    San Diego Ca
    New floor install
    Thanks for the info. I checked out your link to your floor rework, nice. Im a newb and summer is coming up so I think I'll patch it for this year. Maybe I'll start that kind of project next year. Its so easy to get everything out of the hull to get to the floor, so I think I'll patch the floor and lightly glue the carpet in for now. This looks like something I'll tackle next year. I only take the it out 5 or 6 times a year, expensive to run (gas).
    Aug 2013
    San Diego Ca
    Where do you get your glassing supplies, any auto store?
    Thanks.
    Quote Originally Posted by rick1964 View Post
    Thanks.
    I used fiberlay in San Diego... The cheapo home-d stuff is not recommended. Check your local fiberglass business. You need the real thick sewn together glass. They have a higher end resin as well.
    Made In The Shade
    Aug 2013
    San Diego Ca
    Thanks I'll check them out. One other question, since it's my first time I have an idea how to start pulling the floor out. Im going to do it next winter. What Im not sure about is the correct method for separating the plywood from the hull bottom . Im guessing its just fiber glassed over on the edges where the plywood meets the hull. Do i score the edge or cut thru the plywood an inch or two in and then work it loose... just guessing... How should I separate them? Want to do it on my own and forethought would be handy
    thanks again
    Rick
    Sometimes you will run into a few screws into the stringers then glass over. Just look for that. You want to be careful on the areas glassed to hull. I would score those. If you have a hand buffer grinder, I would get some coarse pads for it to sand. You need a good mask for your lungs to...
    Made In The Shade
    Sep 2012
    Thanks.
    west systems
