swnd plates
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 107
swnd plates
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default swnd plates
    any more advise on what you guys can see here? This was previous configuration when I bought this beast? When restored I left these setting as they were at! why is outer plate 0 degrees with bottom and inner plate is 3.5 degrees negative? ride plate is 3.5 degrees posotive? dont know what hyd diverter angle was at? sorry please see post # 3
    Senior Member Futs's Avatar
    Orange CA, Big River
    Start with the outer plates @ 1* up and the ride plate @ 3.5* up. Safe starting spot. see where the boat rides. What kind of shoe and where is it in relation to the keel?
    Sep 2008
    beaumont ca
    Default swnd ride plates
    My outer plates read 0 deg. inner side reads 3.5 deg neg at inner.Center ride plate ride plate 3.0 deg pos. motor is 5 inches from block not valve cover to rear transom. dont know why previous owner set angle of plates at different degrees as to inner sides? Im confused as what I heard from these adjustments? Should they be level even all the way across. This boat has only seen 90,s in it with me and (Precious cargo before shutdown) (a twin bro). 18 to 20 inches of freeboard! boat at this speed felt stable? unsure of top speed as gps will be in order for elsinore if I have the peanuts to run all out!also can someone tell me about my shoe configuration? Guys thanks in advance!
Name:	80 SOUTHWIND tank and plates 076.jpg
ID:	23212   Click image for larger version.
Name:	80 SOUTHWIND tank and plates 027.jpg
ID:	23213   Click image for larger version.
Name:	80 SOUTHWIND tank and plates 078.jpg
ID:	23214   Click image for larger version.
Name:	80 SOUTHWIND tank and plates 105.jpg
    Sep 2008
    beaumont ca
    Default race tank
    pic of race tank done! another seat cover shot. seat goes out tank goes in! If anyone wants killer deal uphoulstrey done e-mail me at [email protected] I will get a contact # for you Riverside CA area! Guy has no computer! Super deal and very reasonable awsome work pic's tell details!
Name:	80 SOUTHWIND tank and plates 075.jpg
ID:	23216   Click image for larger version.
Name:	80 SOUTHWIND tank and plates 002.jpg
    Senior Member Mouzer's Avatar
    corona ca
    finish it off with a matching cover over the front of your scoop..........
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Set the air plates even all the way across. The shoe looks to be a tappered shoe. Kinda hard to really see whats going on.
    is this one of those shoe rideplate combo deals?
    you know like from the early 70's when they used the rideplate as the shoe then added a spacer to lower it???
    #55
    F'ed up disease=boating Jr Jetter's Avatar
    Charlotte, NC
    As Futs states... set the air plates at zero all the way across. Youre simply extending the hull, not correcting anything.
    As far as the ride plate, it varies... mine likes 4 degrees up for all out speed, but its very loose. So normally I run the ride plate at 2.5 degrees up to make it 'lakeable'. Then I can simply remove a shim from under the ride plate cradle and be back to 4 up.
    With the plates, and pod (extended pump), youre just making the boat think its longer than it actually is. Basically a extreme set back pump, and the plates make the hull think its longer as well.
    2 degree back cut shoe worked best on mine, cant tell what yours is though.
    Wow, from that pic it looks like a bolt on plate with a spacer for the plate and NO shoe. I don't know what im talking about, so just ignore me..
    Sep 2008
    beaumont ca
    Default shoe
    Does this pic help? looks like a 1/4 inch extension plate mounted flush with intake.
Name:	scoop cover 004.jpg
ID:	23232   Click image for larger version.
Name:	scoop cover 005.jpg
    Sep 2008
    beaumont ca
    Quote Originally Posted by Mouzer View Post
    Okay mouzer here's the scoop cover!
Name:	scoop cover 002.jpg
    Quote Originally Posted by swtd View Post
    we need an aged opinion, where is Shoemaker??
    yeah that what I was talking about, the rideplate has the cutting edge.
    and the spacer sets the depth.
    #55
    Angier, NC
    Default set up
    run mine with a 2 deg back cut shoe and plate at 3.5 up and tunnel plates at 2 up that is what tim futs told me to start at with and it went 88 right off the trailer with no tuning it was a good starting point
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    B1 Racing cs19's Avatar
    thats an old skool setup right there.
    B1Racing.net
