how fast is your boat?
Page 1 of 42 1 2 3 4 11 ... LastLast
Results 1 to 14 of 575
    Default how fast is your boat?
    this could turn into a good source of info. dont care if its a drag boat, circle boat,lake boat or fishing boat.
    give us the following:
    hull/weight: 19 Ultra Shadow/525 lbs
    Engine/power: 582 spread port BBC/1280ish hp
    pump: Berkeley suction housing, Dominator bowl, aggressor stainless B/C impeller, place diverter nozzle
    Top Speed and/or ET: 132.8 mph / 7.86 seconds
    Hey moderators, can we make this post a sticky up top of the board?
    This will be great info for my "Efficiency" thread. I hope you get some more of the racer's to post up.
    http://www.performanceboats.com//showthread.php?t=19487
    Thanks for your numbers:
    hull/weight: Cal Performance 19' open bow, 775 pounds bare, 990 lbs pump and interior
    Engine/power: 565" BBF A-460 heads, 935 hp, 1,150 (nos)
    pump: Berkeley suction housing, AT bowl, Legend B cut SS, place diverter nozzle
    Top Speed and/or ET: 108 mph in 1,000' w/nos @ 6,900, 99.5 @ 6,200 w/out
    Sleeper CP
    Big Inch Ford Lover
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    not as fast as your guy's
    Golden Shores,AZ
    hull/weight: 18 CoLe jet boat/550ish lbs bare
    Engine/power: 514 BBF Blue thunder heads/800 ish
    pump: Berkeley suction housing, Aggressor 9 vein bowl, a/t stainless a/b impeller, place diverter nozzle
    Top Speed and/or ET: 10.59 et is my best. 97.14 mph is my best all at the world
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Hull----1975 Miller semi-v
    Weight bare----unknown. 600-700lbs
    Engine----509" BBC, 10.6:1, single Dom 1050, 150 shot
    Power----685hp @6000, 830hp @ 6100 w/n20
    Pump-----Berk JC suction, JG bowl, ss b+, shoe, rideplate, Older model PD
    Top speed so far---87 mph @ Pyramid Lake, elevation approx 1800' + heat, + humidity = more like 2500' elevation.
    Still haven't been to the river, or any lakes at lower than 2000'+ elevation. Haven't hit the button yet either.
    I'd be pretty stoked to crack 90 mph @ the river or with setup changes. Mid 90's on the button would be pretty cool too.
    Peoria, AZ
    Where's Braaksma when you really need a bit of "One-up-man-ship?"
    Golden Shores,AZ
    RR what cam you using and what comp im thinking about uping mine from 10.2 to 11ish i got the 85 cc bt heads i think i would be ok on pump gas
    FAT GUY IN A TPR STEALTH NO REGRET$'s Avatar
    MENIFEE . CA
    hull/weight: 19 TPR STEALTH 450 lbs
    Engine/power: 510 BBC 12.7/1comp. AFR heads 1150 DOM.
    pump: Berkeley suction housing,AT BOWL AT stainless B/C impeller,DPS INDUCER
    Top Speed and/or ET: 102.9 mph / 10.29 seconds on motor.
    106 at the river an 113 on nos 119 mph with blunder.driving..117 degrees 80% humidity
    6200rpm on motor , 7200rpm on nos no dyno info 250 shot zex perimeter plate
    "Life's tough......It's even tougher if you're stupid."
    -John Wayne
    ..JUST HAVING FUN..
    . . . .SIPPY CUP RACING. . . .
    MySpace URL:
    http://www.myspace.com/dp734taj
    spokane, WA
    hull/weight: 19 eliminator daytona/550
    Engine/power: pump gas 496 twin turbo/1150
    pump: TSR(Tony skagen racing) pump, dominator bowl, 9.5 high helix AAA stainless impeller, shoe, ride plate, manual diverter
    Top Speed and/or ET: river is done for the year, any guess'?
    Senior Member HBjet's Avatar
    hull/weight: 19' California Performance Gullwing / 1765lbs complete with approx 6-8 gallons of gas.
    Engine/power: DNE 496 All Iron pump gas BBC / 730hp at 6300 rpm in 2002 on 91.
    Pump: Berkeley suction housing, MPD Converted JG bowl, MPD Berk stainless B impeller, AQ Shaft, Inducer, MPD Loader/Shoe/Rideplate. No diverter
    Top Speed: 95-96 mph on 91 (5950 rpm) / 104 mph with 150 shot of N20. (6350 rpm)
    (8 second passes at Irvine for numbers)
    Sacramento Ca.
    ok ok ill be the underdog lol...
    74 tahiti super tiger bubble 875 lbs
    very tired oil blowin berring clankin 455 low 400 hp range maybe...
    berkeley pump, jc bowl and diverter cavitating like a bitch with an aluminum C impeller
    top speed down river wind at my back folsom and nimbus damn flowing at full capacity........66 mph LOL!!
    havent run my new setup yet though,
    fresh motor should be easily within the 500 hp range fresh pump aa impeller jg bowl, droop, diverter, ride plate hopefully mid 70's
    anyone wanna race?
    jabrun jabrun's Avatar
    Sep 2008
    Mitchell SD
    Quote Originally Posted by matt1840 View Post
    anyone wanna race?
    You'd beat me in a race. '83 Sleek Craft Kauai 19' 6" weight unknown, stock truck 454 with small oval port heads approx. 250hp. Berkeley 12JG drive 52mph. @ 4100rpm.
    The Right Coast/SE-PA
    this could turn into a good source of info.../
    Sure, hopefully it'll keep on topic
    Glendale Arizona
    Hull/weight: Earl Smith TX-19 approx 500 lbs
    Engine/power: 468 cu in BBF approx 500 hp +200 NO2. Tunnel ram'd with a pair of Holley 660s.
    Pump: Berkeley rebuilt (worked) by MPD, stainless A imp, backcut shoe/rideplate, loader, C bowl converted to G, short JBE droop snoot.
    Top Speed and/or ET Repeatable via gps 82.5 mph on the motor (5200 rpm), 92.7 mph @5800 rpm on nitrous w 2 people and full tanks.
    All speeds with a full compliment of "I'm at the river/lake" crap.
    I keep editing because it keeps changing. Fortunately still going in the right direction.
