nozzle height placement
    Dec 2012
    Default nozzle height placement
    i run a 2004 Cobra V hull with a 454 and setback Dominator pump. The boat runs well and dry at higher speeds but seems to throw a lot of splash off of the pump at lower speeds (below 3200 rpm) even though the boat is well on step. i was wondering if there is any rule of thumb about where the nozzle needs to be in relationship to the keel line on a v bottom for a good starting point? i have several different snoots i can try to move the nozzle up or down in relationship to the water when running.
    Shell Knob, MO
    Are you running a shoed intake with a ride plate?
    Dec 2012
    i'm running a shoed intake but no ride plate at the moment
    gets 'em wet ultrajet's Avatar
    folsom, ca
    Quote Originally Posted by kaptainkrash View Post
    What Cobra mold do you have, the 185 sidewinder model?? If so I have the same exact hull (2000 ultra) with setback dominator and run 2* back cut shoe with rideplate and droop and it is pretty dialed in.
