Through transom cable seals?
Results 1 to 7 of 7
    Sep 2009
    Default Through transom cable seals?
    All i can seem to find is the cheap looking stainless seals that are held on with 2 screws. Is there any other option out there for diverter and reverse cables? I would like something that has a packing nut that i can tighten. I have seen them for 33 series cables but cant seem to find any for 43 series cables. What have you guys been using and where did you get them? Thanks for any help!
    Senior Member Rivieraracing's Avatar
    Jul 2012
    Oregon
    Senior Member Futs's Avatar
    Orange CA, Big River
    grainger
    Jan 2013
    Magic Mountain CA
    I think I bought one from Teague
    San Diego, CA
    Look under liquid tight cord grips. Usually used around water tight electrical connections. You can usually get these in stainless, plastic, and aluminum. Packing nut, seal very nicely.
    Mcmaster carr will have them.
    Boat 405.
    We manufacture these cable seal fittings in direct fit "no leak" for Berkeley and Dominator transoms , as well as bulkhead type and weldable
    Sep 2009
    Awesome, the ones on jbp look like what im after! Ill be needing the bulkhead style, i will get with you tom whenever i get a few more things that i need. Thanks guys!
