Back Cut Shoe
Results 1 to 14 of 33
Back Cut Shoe
    sacramento
    Default Back Cut Shoe
    what exactly does a back cut shoe do for a "v" bottom hull like a 19'? i think it adds lift, but what else does it do? less water pressure?
    It changes the biting edge location, while making the ride plate lower. Allows you to not over stuff the pump, with shoe, yet let the boat step up and ride on the plate. Kind of like having the shoe running deeper than the keel, but with out all the bad stuff on shut down. Lets you run flatter and drier, makes for quicker ET's at the track.
    sacramento
    i'm getting it now!! thank's!!!
    sacramento
    how exactly does it help on e.t.'s
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    i'm guessing that since it runs flatter the boat isn't acting like a sail thus cutting off time on your ET
    "i'm into snatchin' kisses... and vice-versa!" haha
    Quote Originally Posted by turbo wog View Post
    Do your'e self a favor. Go out in the yard and grab the garden hose then turn it up full blast. Then put your'e thumb over half the opening. less volume and more thrust. Then go in the house and think. Whats going to work for your'e application.
    Hull lift. Less wetted area to push through the water.
    Sleeper CP
    Okay, lets try this. Define back cut-shoe.
    Would look something like this:
    The opposite of taper. The tapered shoe is thinner and the rear end and relieves water out the back in. A back cut is sloped down at the rear end and compresses water for lift. Or something like that.
    Sleeper CP
    Hey Sleeper, I was playing in the soup and figured someone would get back! You being a big ford guy, go to my post and reply. That would be a stock bore and stroke 429 scj.
    Where ? Bump it please.
    Sleeper CP
    Sleeper CP
    SWTD circa 1980
    sacramento
    thanks guys . it seemed to work o.k. but i lost the motor that day ..three spun mains & one ready to go .plus two rod bearings ,cam dammage also test & tune session over for now!
    That sucks!
