[Question] straight or droop for this big float
Results 1 to 5 of 5
    Member wriedt cruiser's Avatar
    May 2013
    Oregon
    Default straight or droop for this big float
Name:	photo (3).jpg wriedt.jpg
ID:	50845023' daycruiser with a jg pump and a place diverter, i was woundering about some input on a snoot for this boat, which would be better a staight snoot or a droop and why? any info would be helpful. also any idea on wedges if i end up with a staight, it has a 4* on it now.
    thanks
    I have a straight with 4* pin. Works better with the bolt on shoe/plate set at 3* up. I tried it by itself and was okay till the plate combo. I have a heavy 18' spectra with a 2" longer bowl(aggressor 9 vane)...putting the thrust out that far has helped out performance overall.
    Made In The Shade
    Custom Window Tinting
    May 2013
    Oregon
    cool, did you use an ARS bolt on shoe and plate and what straight snoot did you find with a 4 degree pin. just curious.
    thanks for the info
    Shell Knob, MO
    PM sent.
    Duane's HTP snoot and shoe/plate combo. He was extremely helpful as well with info and instructions.
    Made In The Shade
