HP guess
Results 1 to 14 of 33
HP guess
    Colfax, Ca
    Default HP guess
    I ahve a tx-19 Condor, 468 BBC. I am turning 6200 rpm with an Agressor B, mag/bronze imp. It has never been dyno'd. What would be an approximate HP???
    I have looked at the charts. But, I would like to see some educated guesses.
    is the impeller stock? if not, who massaged the front and backsides and what was done to it?
    Colfax, Ca
    Duane @HTP massaged the imp. It also has an inducer. I can't give specifics about the imp. I leave that to him.
    Southwest corner AR
    A little info. on the motor would help! Comp.,cam,heads,cubes,stroked or not? WT
    WT
    WFL Crew!!!
    600ish.
    i've ran a dominator(amt) b-cut, aggressor a-cut, and amt aa-cut all within the past 4months in the same hull
    Colfax, Ca
    468 BBC, Merlin 345 iron heads
    Comp cam, .715 lift, int dur- 260, ex dur-272, 114 lobe center, overlap 38
    tunnel ram, two 850 holleys
    13-1 compression, full roller
    Senior Member BigBoyToys's Avatar
    Spokane, WA
    1200 hp at least!
    Ok, seriously now, I think that motor was dynoed once upon a time Tim. I don't remember the HP but it was higher than 600. Wasn't that the motor out of my CP Tunnel? Hell, I can't even remember that.....
    "That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government"
    Declaration of Independence, July 4, 1776
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Quote Originally Posted by BigBoyToys View Post
    1200 hp at least!
    another e bay jet
    I would estimate somewhere around 7oo hp
    [/SIGPIC]
    Southwest corner AR
    I have run a 468, 10:1 comp,Brodix BB2 660ish lift cam 1050 dom. 660 HP! So I would guess more in the 695-720 HP range! I only turn a Berk A at 5400!
    WT
    WFL Crew!!!
    Spokane, WA
    Quote Originally Posted by Lucky View Post
    another e bay jet
    This motor was in a boat running around your neck of the woods a few years back...at Clear Lake.
    Is this the motor Tim?
    and here at the races @ 101 mph
    Spokane, WA
    I was thinking it was around 750 but I may be wrong...
    As I recall, there was alot of work done on the heads and intake. They flowed pretty good
    Colfax, Ca
    Thats the engine, Jim. I can tell by the purple.
    Lucky, if it was on Ebay, it would 1400 hp and 150mph
    Spokane, WA
    Yep...Gotta love that ebay stuff
    When I purchased the boat, I saw the dyno slip and it was something like 742. Have you made any changes to it? Was it tore down after the NYD mishap?
    I did have Rex Hutchinson (Glen actually) work on it a little after I got it.
    Ukiah,Ca
    was it a freightrain motor ?
    [/SIGPIC]
