Tunnel Ram Advice
Results 1 to 14 of 15
Tunnel Ram Advice
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Default Tunnel Ram Advice
    So I'm getting ready to install a newly acquired tunnel ram from my single carb setup can you guys give me any advice on what challenges I may encounter. Throttle cable, fuel system routing/requirements, clearance issues, performance expectations, I don't know anything you guys can give me a heads up on would be great. BBF Offy TR carter 625's replacing Holley 850dp
    Pics would be great!!! Thanks
    Shhh!! Can you hear that?? GJ
    Santa Clarita,CA
    Dual 625's
    Maple Ridge B.C. Canada
    didn't we JUST do this!!!
    dyno section third or so down
    Quote Originally Posted by rogerroost View Post
    I put that link in my post but I didn't break it up very well so I just did an edit. Maybe he'll see it now.
    Nov 2009
    If he can't see THAT.......He won't ever SEE an EXTRA carb anyway! Lol
    Glendale Arizona
    Quote Originally Posted by GottaJet View Post
    what challenges I may encounter. Throttle cable, fuel system routing/requirements, clearance issues, performance expectations, Thanks
    All that and more.
    In particular, it's a tight fit between the distributor and TR on the BBF. I used the MSD Pro Billet Part No. 8577 and there's only about 1/8" clearance between it and the TR so real tight. Mine's a Weiand and not an Offy so you might have more room than I did.
Name:	IMG_0152 (Medium).jpg
    After having done this I would recommend not doing it. I made the switch quite a number of years ago and it ran fine on the TR setup with a pair of 660's, but there were no gains. My old 850 dp on a dual plane manifold hit the same numbers and was easier to keep tuned. It was a lot of work and money for bling. For the past two years I've been plagued with carb issues even after paying a professional to rebuild them both. Just recently purchased two brand new carbs in an attempt to get it running like it should. I should have left well enough alone.
    I've seen guys post up gains when switching to TR setup would rival a blower swap, but I got zilch. I think on a 10:1 or lower compression deal with mild cam it's pretty much just a waste money.
    If I had it to do again I'd probably go with a Victor JR single plane manifold and a single 1050 dominator.
    This is just an opinion based on my personal experience with a similar situation.
    Santa Clarita,CA
    Wow! tough room
    Sorry didn't mean to waste anyone's time
    Thanks Squirtcha, you definitely gave me something to think about.
    Thanks for the link ICECREAMAN
    Glendale Arizona
    Yeah sorry about that. I'm sure that wasn't what you wanted to hear.
    I paid a ridiculously low price for my TR and the two 660 Holleys. I figured at $250 for the TR and carbs how could I go wrong. I paid another $250 to have it polished and later another $150 to have it ceramic coated because I'm too lazy to keep polished pieces polished. I rebuilt the carbs myself a couple times over the 10 years that I ran them and like I said, they worked fine, just never got any gains from the swap.
    I'd be curious to hear some success stories of people with relatively low compression (10:1 or so) mild cams going from single carbs to TR and duals and getting significant gains, but I'd be surprised.
    Dan, I have a BBC with 10:1 deal, I put a edelbrock tunnel ram with (2) 850 demons, I gained 40mph when swapping from a single plane holly deal.
    its a Chevy so preformance gains may vary! Lol
    Nov 2009
    That is funny!
    Glendale Arizona
    You should share your secrets with the OP.
    Senior Member TrollerDave's Avatar
    Chino,CA
    Uhm... go Chevy.
    and a new cam, new heads, NOS, and...etc.
