Torque or RPMS?
Results 1 to 6 of 6
Torque or RPMS?
    Feb 2014
    Yakima, wa
    Default Torque or RPMS?
    Which is more important in a jet boat?
    Once I get the dual quad set up on this one I am going to look into starting a stroker for the Tahiti. I have noticed that the bigger the cubic inches on the stroker, the more they refer to the power being low-end and not up in the RPM range.
    I'm not sure what I ought to be going for in this instance?
    I like speed, but let's face it, my boat is not a race boat and I have way to many other projects to ever compete with some of the boats on the lake performance-wise. I just want as much grunt as I can get with a naturally aspirated Big Block.
    Feb 2014
    Yakima, wa
    Well, this looks like another popcorn thread.
    After a better search job, I see there are lots of answers here.
    Sorry bout that! Just new and excited to learn stuff.
    Mar 2010
    Clarksville, TN
    If you won't to stick with a standard block(454 block) the 496 is a great engine. If you won't to go aftermarket than you can step up to a 540 or bigger. Bigger cubic inch never hurts, just really have to ask your self how much money you wonna spend. In a lake deal I'd like to keep the RPMS low and get several years of use out of it.
    Feb 2014
    Yakima, wa
    Thats me, lakin' it. I just want to have some grunt to get outta my own way in a bit of a hurry, and logevity. Reliability is really important. No one wants to be left out there sitting...
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    If you impeller it for RPM you cruise at a higher RPM also.
    QE 439 Twin Turbo
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by SuperTiger77 View Post
    Good power and a big impeller and you'll run it for years with very little maintenance
