Header caps or plugs?
Results 1 to 9 of 9
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    Default Header caps or plugs?
    Did a search and didn't come up with any threads on this. Im having my Bassett twisties coated and am planing to run them dry however, I would like to plug or cap the water injection bungs so if decide to go back to runing water. Sizes, where to buy, options and any pics?
    Mar 2010
    Clarksville, TN
    It's just a 1/8 pipe plug. You can get them at any hardware store. I use brass
    Sep 2009
    Concord, NC
    Thought that too but, True value, and Lowes were a no go. Only thing I could find is ones like this:Socket Pressure Plugs | MSCDirect.com
    Will these work or do the need to have a head on them like these? 1/8" Male NPT Brass Pipe Plug
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    Napa should have them. They're just standard pipe plugs. You can order them from mcmaster carr too if you can't find em locally
    Feb 2014
    Cottonwood, Arizona
    A hardware store should have them. Do you have an ace?
    Those are exactly what I used when I was running dry.
    Senior Member BGMAN's Avatar
    Standard 1/8 pipe plug will work. I would suggest installing them with some copper anti-seize since you might want to take them out later. I would also suggest brass and stay away from a allen headed plug. Even with anti-seize, they are a bugger to get back out if they have been on for a while and the allen headed plugs always seem to strip.
    Sep 2009
    Concord, NC
    Thanks for the info. I will order them is If Ican't find um locally.
    Jun 2011
    Artesia, CA
    Quote Originally Posted by BGMAN View Post
    Good info. I have the Allen headed ones cause they look a little cleaner IMO. But I take em out every so often and put more anti seize on em and clean out the threads. Sucks if they round out or break.
