Hydraulic Pump Mounting
Results 1 to 14 of 35
    Senior Member cbcp's Avatar
    Carlsbad
    Default Hydraulic Pump Mounting
    How are you guys mounting your Place Diverter Hydraulic Pump ? It came with some joke of a mount which wouldn't prevent it from bouncing around. I don't have any ply wood glassed into the transom so it looks like I'm going to have to mount it to the stringer but wanted some input before I start drilling holes. Any input appreciated.
    the last three boats that had place diverters I used the mount
    that came with it. works great, just mount it leaving the screws a little loose slide the pump on and tighten the screws. never had a problem.
    #55
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    I glassed a small piece of wood to the transom and used the mounting kit it comes with and it worked perfect. i tryed making a few brackets off the stringer it just wasnt clean at all.
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
    I used existing thru hull bolts, from my tunnel plates. Made up an angled bracket from the tunnel plate bolts, to hold the pump assembly about an inch off the tunnel. I used the mounting bracket that came with the pump, bolted it to the aluminum bracket.
    Anaheim Hills
    I use the same part you have. Just dab a little grease on it and keep your eye on it.
    There was a guy on Hot boat that made some bitchen looking bracket, this was right before the sight took a shit so I never got his number.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    same here. I had to mount it to the stringer, no room on the transom.
    Can you use some thing like this?
    http://cgi.ebay.com/ebaymotors/Bille...mZ380076006041
    nice!
    #55
    Anaheim Hills
    Very nice
    Carlsbad
    Now that's what I'm talking about, are you making these?
    Quote Originally Posted by cbcp View Post
    No, but if I put a PD back in my boat I will be running one.
    LaGrange GA
    That's sold by the "How to drink a beer in a boat" dude!
    El Cajon, CA.
    Knowing someday I'd be ditching the black plastic battery box that holds my diverter's hydraulic pump I saved a link to this thread. This is the bracket that I used. I did expand on it a little bit but it worked out really well. It's a nice part.
Name:	divertor bracket 3.jpg
ID:	26881   Click image for larger version.
Name:	divertor bracket 4.jpg
    Senior Member activeshack's Avatar
    Virginia
    Mine was on the stringer when I got the boat but I moved it under the jump seat. I used a block of wood and epoxyed it to the seat frame. I would love to have one of those billet brackets to replace the plastic one.
