Priming motor after long winter storage.
Results 1 to 5 of 5
    Apr 2012
    Default Priming motor after long winter storage.
    Wanted to get the general consensus if pulling the dizzy and priming the motor would be a good idea or unnecessary work after 8 months of sitting idle. Boat is stored outside, and engine was built new last season. Thanks!
    Senior Member David_396's Avatar
    Hanford CA
    Change the oil, pull the coil wire, turn motor over to build up some pressure. Re-attach coil wire. Fire the bitch up.
    Lake Havasu az.
    Stored outside it might have picked up some surface rust on the cylinder walls, might be a good idea to pull the plugs before you crank it over.
    Sheriff Joe Arpaio
    San Diego, CA
    Quote Originally Posted by Bonzen View Post
    Why not? Easy enough to do. I pull the dizzy just to change oil in my river cruiser. When you prime the oil system have someone hit the starter too, ( obviously have the coil disconnected) That way it can build oil pressure and get everything since it's been sitting for a while.
    I think peterson has a new remote oil filter set up that has small pump in it that you can use to prime the oil system. Pretty cool little device.
    Boat 405.
    Apr 2012
    Thanks for the replies guys.
