Heddar bolts
Results 1 to 14 of 15
Heddar bolts
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Heddar bolts
    Anyone always tightening hedar bolts? I have to every time I shutdown. using 12 point 3/8 bolts 1 gasket. looking for support brackets if anyone has a set used? Just hate to add weight.
Name:	454 small.jpg
    copper header gaskets and fagetboutit
    Senior Member wajetboy's Avatar
    Auburn, WA
    i have a set of header braces for sale i will get a picture if you are interested.
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Member blownt's Avatar
    Houston, Texas
    Stage 8 has header bolt locks. Just a triangular place that slips over the hex of the bolt then is held on with a C clip. Triangular piece fits against the header tube and stops it from spinning. Used them on the hot rod not the boat yet.
    check these out.
    http://www.stage8.com/products_lhb.html
    High Rock Lake, N.C.
    Header studs work for me. Plus no fighting to hold header up when mounting them.
    http://store.summitracing.com/partde...3&autoview=sku
    Sep 2008
    beaumont ca
    Quote Originally Posted by wajetboy View Post
    Intrested with price and location. Thanks everyone will use the locks also on another dellio!
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    I got aviation bolts. Socket head cap screws with the holes drilled in the top. Tighten them up and coil wire between the whole side. Looks bitchin like a fighter plane. Also use these bolts and run a copper gasket the fiber type tends to expand and contract more.
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Fought that probelm for 2 year's until I mentioned it to my dad who was an old time hot rodder. Studs and brass nuts.. no washers, fine thread stud's and brass nuts and they don't back off even after many Nos passes.
    Sleeper CP
    Newton Ks.
    Fine thread studs, metal self-locking nuts (not Ny-locks), and Hi-Temp RTV.
    Never loosen, and no leaks.
    H.L. Mencken
    B1 Racing cs19's Avatar
    Default Heddar?
    its spelled header.
    B1Racing.net
    Sep 2008
    beaumont ca
    its spelled header.
    thanks for the correction.
    I use SS allen head bolts and lock washers
    Tacoma Wa
    Im cheap and just cinch them down at the end of the day. I paid enough for the damned SS header bolts.... Friggen ARP getting their pound of flesh......
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Quote Originally Posted by blownt View Post
    check these out.
    These are the only way to go! We run em on every motor and never had an issue.
    Do it right the first time and be done with it!
