Plugs
Results 1 to 6 of 6
Plugs
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Plugs
    Is it beneficial to index plugs with washers? weather you run race gas or diffrent distridutors mag vs hei? seat of the pants or h.p. increase? and where do they normally point the electrode? thanks
    Quote Originally Posted by swtd View Post
    helps expose the spark kernel directly to the combustion chamber, and can help reduce chances of detonation. Do you cut back the ground strap on the plug?
    Sep 2008
    beaumont ca
    On my vertex mag their cut back 3/8 inch. when motor was freshly assembled plugs were indexed and gapped to 18thou. and fire coccoa brown. she fires strong.
    Cantard 71hallett's Avatar
    snow bank
    Between 10 and 2 O clock.
    The Right Coast/SE-PA
    Wouldn't that be high-noon?
    snow bank
    Or happy hour.
