Oil pump recommendation help
Results 1 to 14 of 17
    Oct 2011
    Default Oil pump recommendation help
    Hey guys i need some help. I have a mild build 454 with speed pro hyper pistons, comp cam extreme marine cam kit. The eninge is done being rebuilt and the bearing clearences are on the looser side. Right now I have a stock oil pan and a HV melling oil pump. Am I asking for trouble? Should I cahnge the pump or the pan?
    Quote Originally Posted by dremmick View Post
    Less than desirable combo HV pump with stock pan, a large capacity pan should be in your plans to protect your investment for sure Tom
    Surprise, AZ
    Imho, I would change the pan.
    Sent from my VS980 4G using Tapatalk
    Oct 2011
    So keep the HV pump and run a bigger oil pan? Any recommendations on pans? would rather not spend $300 plus dollars on a pan
    Surprise, AZ
    It's your motor, oil control is very important. Even with a standard pump, I would run a marine style pan. There are a few good pans out there, Armando or Stef are excellent pans. I haven't heard too many bad reviews of the canton.
    Oct 2011
    Which oil pump do you recommend then a standard or HV oil pump?
    You posted a clue to your own answer here,, although you didn't indicate what the bearing clearances are. I have been using high volume pumps for many years on literally hundreds of big block Chevy marine engines.
    As others have mentioned, you do need to spend money on a decent pan to help protect your investment, even if you buy a good used one. What's a couple hundred more dollars compared to possibly destroying your fresh engine?
    This video from Melling shows flow difference for various bearing clearances, and makes an obvious statement for why someone would run a high volume pump. Remember that the high volume pump has 25% longer gears, so basically should be able to flow 25% more oil, and then look at the difference in oil flow for the various bearing clearances. This also visually demonstrates why different engines may use different weight oils.
    Oct 2011
    If my memory serves me correctly I went with .00275" on the rods and .003" on the mains.
    OK, the video shows what .003" does for flow. I would definitely keep the high volume pump and get a better pan
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    if you are going to use a stock style pump I like the Melling Select 10770 pump. It comes with a nice hardened drive shaft. And get a good pan please.
    QE 439 Twin Turbo
    Mar 2010
    Clarksville, TN
    Hamburger makes a good pan for the money, got several friends that run them .. Might as well put a HV in it to be on the safe side
    MD
    im running .0025 and .003 on my bbc I feel the bigger pan would be the better investment
    on another note for the guru's im running a 10778c pump and was told to leave the HP spring in it.
    what would be pressure diff. be from the HP and the LP spring ??? on my old motor the LP spring gave 70lbs cold and 55-60 hot
    can I still run my 80lb gauge ??
    not trying to hijack the thread just thinking this info mite help the OP as well
    Hamburger's 1498 Hamburger's Oil Pans - Free Shipping on All Orders @ JEGS
    Jan 2013
    Magic Mountain CA
    I'm running this pan. I like it. Mellings HV oil pump as well. No issues.
