impeller issue
Results 1 to 14 of 70
impeller issue
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Default impeller issue
    what would cause this?
    it's an AT A/B with about 40 hrs on it. You can see the the chunks out of it are at the same location at each vane along with the cracks the go along the wear surface following the shape of the vane.
    B1 Racing cs19's Avatar
    post a few more pics.
    B1Racing.net
    Cas
    Cas is offline
    these are all I have,
    What kind of loader are you using Steve?
    The Right Coast/SE-PA
    It almost looks like the Impeller was expanding at the blade ends along the wear ring band, cracking (aluminum) and breaking apart.
    Maybe too much HP?
    Of course I could be totally wrong
    Did you ever check the impeller to be true?
    Cas
    Cas is offline
    There was a full blocker used for about 4 or 5 hrs, I thought about what you or someone you know went through with the blocker. A semi blocker was also used for a short time while the testing and tuning was going on
    Maybe too much HP?
    engine is about 500 hp so it could be too much hp for this particular brand?
    Quote Originally Posted by Pw_Tony View Post
    yes, it was checked
    Cas
    Cas is offline
    ok, here is another pic of the opposite side-
    I don't know if it's just the pics, Steve, but that wear ring skirt looks awfully thin. Has this impeller been reworked or was it new when installed?
    cavitation
    B1Racing.net
    Cas
    Cas is offline
    it was brand new Craig
    Cas
    Cas is offline
    Quote Originally Posted by canuck 1 View Post
    Cavitation
    What hit the blades?
    no clue what hit them
    MI
    Aluminum impellers and blockers don't mix. I thought we covered this before.
    Cas
    Cas is offline
    Quote Originally Posted by sanger rat View Post
    we did and I learned that lesson. The blocker used with this was approx 8" long measuring from the plate back
    What is the marks about an inch from the hub?
    it looks like little nicks from something?
